Brake Disc Size
Brake Disc Size
Hi guys. Just wanted to the brake disc size? As I'm need to change the discs on my car as they are warped?. The question is which size fits for 6r GTI? 288mm or 310mm or is there any cross reference part numbers from the VAG group will fit?. Thank you.
Re: Brake Disc Size
Both sizes could fit. Get out the tape measure to be sure.
