GTI tyre pressure loss indicator issue?
LEEA123
Drives: none
Post by LEEA123 »
Hi there so was driving yesterday, then had the light on dash showing tyre pressure loss . When i stopped o checked the pressures for tyres and they was all ok so i reset the sensor on the screen . Warning has not come on again, but the we connect app still shows a warning on the health report and cant seem to reset that . Any advice how too at all ?
Metman888
Drives: 2022 Polo GTi
Re: GTI tyre pressure loss indicator issue?
Post by Metman888 »
I’ve had the exact same problem today. Reported as front left but when I’ve checked the pressures are fine. I did have a strange abs activation the other day though, was slowing normally up to a set of lights and felt the buzzing as you do when the abs kicks in but I wasn’t doing anything remotely near what you’d think to make it trigger. I’m now thinking it might be a dodgy wheel speed sensor.
Maarten
Post by Maarten »
The app refreshes every day.
So a notification in the app, when sorted, will be gone the next day (Usually)
