Rough Idle
Polo Mills
Drives: 2005 Polo 1.4
Rough Idle
Post by Polo Mills »
So Newbie here, just recently bought a 1.4 Petrol Polo and have noticed that it has really low idle and sounds a little lumpy but does not stall when at a standstill. I have done a little bit of digging myself on the forums. So far I have cleaned the maf, bought new spark plugs and coils but still to this day it is not running Smoothly with a low idle. I have also had the codes read with nothing to report. This has been covered loads on the forum I know but could anyone with a little more experience guide me in what to check next. Any help would be great, just trying to get the car right for my boy for when he passes his test.
Johntheo1
Drives: 2018 MK10 AW1
Re: Rough Idle
Post by Johntheo1 »
Suggest a compression test.
Polo Mills
Re: Rough Idle
Thanks for the reply ref the compression test. I have just conducted this and found that all cylinders have strong compression with all similar readings. Nothing was low and looks very healthy. What would you all suggest next?? Any help would be great.
