2014 polo 6r bcm upgrade.
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
I am currently upgrading my bcm from 6r0937087P to a 7h0937090B however on doing so the windows no longer work and Instrument cluster not responding to turn signal or headlight activation. I have found documentation on how to fix the issue but it all uses premade looms. I have the experience and equipment to make my own looms but do not know what cable ends pair together or what looms are needed.
bcm-fuse loom1 Image
or
bcm-fuse loom2 Image Image
Thursday,10,July,2087,23:40:27:10494
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWZZZ6RZEU047965   License Plate: ML14OXH
Mileage: 124120km-77124mi   Repair Order: 3
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 61
VIN: WVWZZZ6RZEU047965   Mileage: 124120km-77124miles
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 AK    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 5151
   Revision: --H03---    Serial number:                CVN: 1A02BB53
   Coding: 00110016002400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12MPI02103E906019AK 001003
   ROD: EV_ECM12MPI02103E906019AA.rod
   VCID: 6D8CA180BD137182D4D-8038
   VINID: 9E69EAAAA1A2A9594010724614BE187589
Readiness: 0000 0100
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 23DD2485212700C7C41D246F845600800905
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F70DB08D7DFE392861-805A
3 Faults Found:
0630 - Tire Pressure Warning
          C102D 00 [137] - -
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 135
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
0631 - Tire Pressure Warning
          C102D 00 [129] - -
          MIL ON - Not Confirmed - Tested Since Memory Clear
0632 - Tire Pressure Warning
          C102D 00 [129] - -
   Serial number: 04021404651883
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EAE96CCE075FA1A7D7-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 392445D0B95B1D22085-806C
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 135
                    Mileage: 0 km
                    Time Indication: 0
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 150130850
   Coding: 39B42FB808E1240092380EC02F6B0CD1F0C8000F60060040200000000000
   Shop #: WSC 124697 483 00190
   VCID: 2D0C61807D13B18294D-8078
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU010011440104657
   Coding: 0000A0
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU016011440162481
   Coding: 0200A0
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0250352 FLE 20130427
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU013011440134195
   Coding: 0000A0
   Subsystem 8 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU013011440135449
   Coding: 1000A0
2 Faults Found:
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 135
                    Time Indication: 0
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 135
                    Time Indication: 0
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0106
   Revision: --------    Serial number: 80231028106035
   Coding: 300001
   Shop #: WSC 00020 999 12345
   VCID: 3B285FD8B3E72F321A9-806E
   Component: VW10Airbag01X H10 0020
   Revision: --------    Serial number: 003GX017A07Y Dataset Number: v00307236R0 0001
   Coding: 003158
   Shop #: WSC 01383 785 00200
   VCID: 4AC60A1CEC3D86BA91F-801E
   Serial number: 3575HRB40572BJ1E99K4
   Serial number: 3585HRB405T2ATKEE8OK
   Serial number: 3515RRB401G50RVQE1OD
   Serial number: 3525RRB400450REKN1U-
   Part No SW: 6R0 920 960 M    HW: 6R0 920 960 M
   Component: KOMBI         H04 0709
   Coding: 140A01
   VCID: 3FD02BC8A7FF3312361-806A
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 135
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 000300
   VCID: 70B2B8F4AAA19C6AFFB-8024
1 Fault Found:
00381 - Databus Instrument Cluster
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 135
                    Time Indication: 0
   Component: IMMO          H04 0709
   Serial number:
   VCID: 6A86AA9C8CFD66BAB1F-803E
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665754124
   Coding: 010100
   Shop #: WSC 31414 790 31414
   VCID: 2B086F984307BFB28A9-807E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11241
   Shop #: WSC 00000
   VCID: 303278F46361DC6ABFB-8064
Address 56: Radio
Cannot be reached
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 032B7A64
   Shop #: WSC 00788 648 00255
   VCID: 6B88AF9883877FB2CA9-803E
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 133
                    Time Indication: 0
02252 - Generator
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 133
                    Time Indication: 0
End----(Elapsed Time: 01:52, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Re: 2014 polo 6r bcm upgrade.
When installing the new BCM you must transfer the old codings from the old BCM and Gateway to the new BCM and "Gateway".
http://wiki.ross-tech.com/wiki/index.ph ... eplacement
If memory serves me right, I think 002300 is the GW coding for your 6R RHD. :?:
Those images that you show for BCM MAX wiring adaptation are not for your European 6R RHD, they are for India 6R RHD.
For wiring, use these guides for your BCM adaptation:
- https://www.uk-polos.net/viewtopic.php?p=514815#p514815
or
- viewtopic.php?p=529913#p529913
or this guide if you do not currently plan to install wiring for automatic lights.
- viewtopic.php?p=520951#p520951
You must take into account that your fuse box is rotated 180º with respect to the 6R LHD.
It is possible that with the BCM 7H0 937 090 B it is necessary to install new CAN lines between the instrument cluster and the BCM. (see installation guides)
From here you can download the wiring diagrams in case you need to consult:
https://drive.google.com/drive/folders/ ... drive_link
The diagrams from the 2009 and 2018 Amarok, and from the 2009 and 2015 Transporter will help you better understand the 6R diagrams.
If you keep this thread active I will help you on some other things that need to be fixed.
edit:
The way to get rid of address 61 from the GW installation list:
- Enable address 61 in Gateway installation list.
- Go to address 61 and code all Bytes to 00.
- Return to GW installation list and disable the address 61.
- Go to Autoscan and Click on Gateway installation list button.
- Click on Clear All DTCs.
The address 61 should no longer be present in the Autoscan.
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
Thanks for helping
I have installed the new can lines. And the windows and IC are now functioning.
I am a little confused with the bcm to fuse loom that is in all the documentation you have provided.
The 2 questions I have.
1) Is it needed In my scenario?
I am planning on installing RLS and auto light just not at this current time.
2) If the loom is needed I have the wiring as;
BCM WHITE 2 -> SB39B
BCM WHITE 68 -> SB39B ORIGINAL
BCM BLACK 2 -> SB59B
BCM BLACK 63 -> SB59B ORIGINAL
BCM BLACK 62 -> SB34B with original daisy chained
Is this correct?
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
JB_Solerz wrote: Wed Jul 12, 2023 1:07 pm Thanks for helping
Is this correct?
EDIT/UPDATE:
I have ordered the required hardware for the rls and auto lights retrofit excluding wiring. However in the installation guides it mentions buying a wiring loom for daylight running
lights but all the links show no results.
JB_Solerz wrote: Wed Jul 12, 2023 1:07 pm I am a little confused with the bcm to fuse loom that is in all the documentation you have provided.
Is this correct?
1) The BCM Max 'adaptation' is mandatory in your scenario or any other.
2) Yes.
Don't forget the new electrical jumper/bridge on the J331 relay (follow the installation guides) - 'place it in the large slots on the relay bracket' -.
JB_Solerz wrote: Thu Jul 13, 2023 12:04 am
EDIT/UPDATE:
You can make these two/three wires yourself.
Where are your DRLs currently located?
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
Hi
Now that all the parts have arrived I have restarted the bcm upgrade. However, I can not seem to find the correct relay to bridge. the pdfs given seem to have a different relay board configuration than my own.
the 1st 646 relay (in the position where the j331 relay should be) is for the fuel pump.
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
Thanks for the help so far.
Hopefully on the final stretch just repinning the light swich T17 to the new 10 and 2 connections.
on all the documentation T17/6 is vacant however I seem to have it populated. Do I just remove and isolate it or does it need connecting somewhere?
Also the current T17/17 goes to bcm white 34. And unsure on what needs doing as the documentation either has it vacant and you add it to 43 Or already installed and nothing else is mentioned
The documentation I'm using:
https://drive.google.com/file/d/1cXw67i ... 9R6DO/view
https://drive.google.com/file/d/0B2nv91 ... N3bT1BRvUA
EDIT:
while trying to find more information about the above, I realized that the document below has the dimmer t6/3 replacement going to bcm white 1 instead of bcm white 4.
https://drive.google.com/file/d/0B2nv91 ... uGBIub5Weg
also ignore the part about T17/17 i was misstaken.
It's t17/16 that you replace.
In your case, you must remove and isolate T17/6 (DRL/TFL* Diode :arrow: 58 for POS/Dimmer/Lincense Plate Lights with BCM High).
A trick that is rather a botch job.(OEM)
You must follow the electrical flow in the diagrams.
It was later corrected on other 6R family PQ25 models.
In short, you must remove and isolate T17/6.
With the BCM Max installed, the activation signal for the DRL/TFL goes through T17/3, or T10/9 in case of installing the new wiring for auto lights. From here to T73b/29 (BCM input signal).
Then you will have to install two new wires for the two BCM output signals that go to the bulbs or LED module (depends on your lighting configuration).
https://drive.google.com/drive/folders/ ... sp=sharing
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
I have now finished the installation and coding.
However;
The dipped beams are constantly on even after ignition and key have been removed. Outside of ch lh time.
The main beams are not activated by the rls
The side lights do not work altogether. Except for ch lh lights
I'm a little confused as some instructions seem inconsistant . As og T17/16 is grey yellow But the installation say grey blue witch is T17/17
the diagram shows og T17/3 going to T10 /7 however you have said in the post T17/3 should be t10/9
From wire tracing I come to the conclusion that you replace T17/16 at T10/8 to T73a/45,
T17/9 at T10/4 to T73b/43,
T17/3 at T10/2 to T73b/29.
Og T17/16 then goes to T73b/7
Og T17/9 then goes to T73a/6
With og T17/3, T17/7 and T17/6 being removed and isolated.
Below is the repinning diagram I followed. And the T17 connector in my polo.
T17/1-9
T17/10-17
I apologize for the following words if they might cause you discomfort, it is not my intention:
The first thing you should have done is post the images with the original wiring of your 6R (as you have seen in the tutorials), because there are substantial differences in the original wiring between some 6R and others depending on equipment, place of manufacture or country of sale.
It is for this reason that I made 'individualized' installation tutorials, requesting those images (T17 and T6 connectors, relay carrier, fuse box, etc.) to those who asked me to manufacture the wiring looms for BCM adaptation. (something I stopped doing because I already wanted to forget about these processes)
'Nothing' is inconsistent or seems inconsistant in my tutorials, they are specific and perfect tutorials for a specific 6R.
That is, you launched into this BCM adaptation without real knowledge or study of what you were going to do.
You don't even provide a scan of your 6R.
As soon as possible, I'll take a look at your previous post to try to figure out (like a magician) what's going on.
I will continue to help you, please be patient, thanks.
Please post a full fresh Autoscan to check 'that' new BCM coding you've done.
If you don't, I couldn't continue to help you. 🤷‍♂️
Clarifications on what you say I have said:
JB_Solerz wrote: Fri Aug 18, 2023 9:51 am I'm a little confused as some instructions seem inconsistant . As og T17/16 is grey yellow But the installation say grey blue witch is T17/17
- Depending on the Model Year and equipment, T17/16 can be grey/blue or grey/yellow. On your 6R it's grey/yellow, it's the power signal that comes out of the light switch (output signal) for 58 signal when a non-MAX BCM is installed.
T17/17 is Grey/Blue in all cases/Model year, which is the input 58 signal to illuminate the light switch.
Note: in the autoscan of the first post of this thread, the BCM is coded for an electrical installation without Dimmer (fixed value).
Does your 6R have a Dimmer installed next to the light switch, or is it just the headlights height adjuster? Take a picture.
JB_Solerz wrote: Fri Aug 18, 2023 9:51 am the diagram shows og T17/3 going to T10 /7 however you have said in the post T17/3 should be t10/9
... the diagram shows og T17/3 going to T10 /7 ... Please show me where you saw this. :?:
... however you have said in the post T17/3 should be t10/9 ... That's right.
What i said:
"With the BCM Max installed, the activation signal for the DRL/TFL goes through T17/3, or T10/9 in case of installing the new wiring for auto lights. From here to T73b/29 (BCM input signal).
Then you will have to install two new wires for the two BCM output signals that go to the bulbs or LED module (depends on your lighting configuration)."
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
firstly I appreciate and thank you for all the help you have given to me and others.
You and the guides you make have been great help.
regarding the confusion over the T17/3 - T10/9. I was up very late when writing the post the T10/7 should have said T10/2. I was referring to the red T10 while you were referring to the black t10 that goes straight to the new switch. I agree that the diagram is correct.
the dimmer in my car.
the coding after the installation.
Thursday,17,August,2023,23:31:41:10494
www.Ross-Tech.com
Mileage: 124740km-77509mi   Repair Order: autolights2
VIN: WVWZZZ6RZEU047965   Mileage: 124740km-77509miles
Readiness: 0110 0101
   Coding: 01
   Revision: 0003SH02
   Coding: 3DB02FB808E1240093390EF02CEB0ED1FFC061FF60062041200000000000
   Subsystem 1 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS 151007 04  46  0204
   Coding: 063025
   Subsystem 2 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Coding: 0300A0
   Subsystem 3 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Coding: 0200A0
   Subsystem 7 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Coding: 020000
   Subsystem 8 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Coding: 0000A0
   Subsystem 9 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Coding: 1000A0
   Coding: 308001
   Coding: 003158
   Coding: 140A01
   Revision: B9074001
   Coding: 003300
   Serial number:
   Coding: 010100
   Coding: 11241
   Shop #: WSC 00000
2 Faults Found:
01314 - Engine Control Module
            49-10 - No Communications - Intermittent
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 02:01, VBatt start/end: 13.0V/13.3V)-----------
while also trying to find where the issue lies. I separated the wiring diagrams for the different looms I made. hope they help.
Please try this new BCM coding:
3DB02FB808E1240093390EF02CEB0ED1FFC061FF60042041200000020000
Please tell us the result. Don't forget to also check the reverse light, rear fog light, brake lights, and license plate lights.
Although so that everything was like factory the final BCM coding should be this:
3DB02FB808E1240093390EB02CEB0ED15FC0612F60042041200000030000
...but I imagine there are still some lights that are not under BCM MAX control, or you have some type of aftermarket light installed.
...so just use this last BCM coding to find out what are the deficiencies of the lights.
Later I will thoroughly review your schematics.
Thanks for posting them. 8)
Your sketches for '6R Europe' BCM MAX adaptation are correct and easy to understand.👌
I would add:
- The output signal T73b/12 for reversing light (only manual gearbox). :arrow: Check diagram.
- CAN lines, T73b/54 (H) and T73b/57 (L), for BCM-IC.
