Re: Fitting a multifunction steering wheel on polo match 6r
No, have a look here: viewtopic.php?t=54171
As you see in that tutorial, you need to add two wires to the T41 connector.
One wire is for communication, called LIN, and another wire is for Positive power.
- The LIN is easier to join/splice in the area of the door connector for the driver's door. The BCM connector area is narrow and not recommended for splicing wires.
- It is better to take the +15 positive signal (12v) from the fuse box by adding a 5A fuse.
Sketch.
For 6R RHD it is mirror image.
It's very easy with the right tools and skills (30 minutes).
It is not Plug and Play.
I think VW has developed an app for smartphones that have installation tools for direct installation.
Music stimulates your senses and improves your intellectual abilities.
Hoorei... https://www.youtube.com/watch?v=gqAcLIezeJc ... for Zumba
https://www.youtube.com/watch?v=1DwH87Xk3cg&t=44s
Sketch.
