Air con button not turning on
Dylbo123
Drives: Tdi 1.2 2012
Post by Dylbo123 »
Hi my car is a vw polo 1.2 tdi 2012 and when I press the Aircon button the red light does not turn on neither does the Aircon , this is also the same with the air recirculation button
Any suggestions would be helpful thanks
Tracendaz
Drives: 1.2 Tsi SE 5 door
Re: Air con button not turning on
Post by Tracendaz »
Hi Dylbo, please don't be offended, but do you have the blower/fan operating when you try to press the buttons?
Kind regards, Tracendaz.
If there is a fault with the AC system, like low fridge gas pressure - due to a lose of R134A, then the system will protect itself.
Dylbo123
Post by Dylbo123 »
Tracendaz wrote: Fri Jul 21, 2023 10:56 pm Hi Dylbo, please don't be offended, but do you have the blower/fan operating when you try to press the buttons?
Yes I do have them on the button doesn’t turn on
Dylbo123
Post by Dylbo123 »
RUM4MO wrote: Sat Jul 22, 2023 9:22 am If there is a fault with the AC system, like low fridge gas pressure - due to a lose of R134A, then the system will protect itself.
I’m not sure don’t even know how to check for errors
I don't know if your cabin air controller can be forced into performing a "self test" and handing out stored fault codes, the earlier fully automatic Climatronic could.
So, if not, then you would need to get this car scanned using an "all systems vag fully compliant" scan tool to get access to any/all stored fault codes - other than doing that, you are just widely guessing what could/might be wrong.
