Auto lock above 15km/h / unlock doesn't work
wide23
Drives: Polo 6R
Post by wide23 »
I tried to adapt like this:
And get info about succesful coding process.
How ever function doesn't work so check again - checkboxes for Bit 3 and Bit 4 are not active like before coding. Whats wrong?
Same situation with Self rain closing. Succesfull coding but no results.
Best regards
Lukas
Re: Auto lock above 15km/h / unlock doesn't work
Hi Lukas, you are the first to report that was unable to code/adapt these functions on a 6R with BCM Max 7H0... Congrats!🥇
Something intriguing, worth studying, may be happening during the coding process... 👽
Please tell us more about the coding process you are doing... can you make a mini video? Autoscan?
Rain closing function needs more actions from you after coding, and the RLS and BCM must have proper HW/SW. -
In 6R, for the rain closing function to work, once the function has been coded in BCM and RLS, it is necessary to reset the comfort window function (owner manual) on all doors again. It can be done from the driver's door window switches.
The result is that only the windows are closed in case of rain.
IMHO, this and other functions due to leaving the car open in the wild are mildly intelligent functions.😁
I know people like to leave their cars open in their natural spaces, I guess so the interiors don't reek of human activity or avoid extreme temperatures, but leaving the car open/ventilated is perfect so that all the interior parts end up in a deplorable state due to dust or humidity.🤷‍♂️
