How to re-fix headliner to roof?
R826583
Drives: …
Post by R826583 »
The headliner on my 2016 Polo has partially split from the roof where a dash cam was installed a few years ago. Any advice on how to re-fix it to where it should be?
Re: How to re-fix headliner to roof?
Post by 2226 »
Why does VW not tuck this up into the liner or include a retaining strip? Absolutely annoying. I bet it's typical VW cost cutting.
Even my later 80s Audi had a retaining edge on the liner.
R826583
Drives: …
Post by R826583 »
I wish I knew why :D
It would be nice if an aftermarket strip existed!
2226
Post by 2226 »
https://www.focusrs.org/threads/what-do ... ke.113582/
We're not alone.
You can get generic rubber edge banding which is usually used to grommets. Not sure how that'd work out.
I'll probably look into that when I drop the headliner at some point to add some noise barrier up there.
2226
Post by 2226 »
R826583
Drives: …
Post by R826583 »
Thanks for the suggestion. I will try that.
R826583
Drives: …
Post by R826583 »
