Upgrading BCM, Exterior Lights, AFS
Andries Polo6R
Drives: Polo 6R Highline 1.2 CGPA
Post by Andries Polo6R »
Good Afternoon everyone,
I do realize that this topic has been opened up many times before.
I want to upgrade my Polo 6R, it is a highline version with a 087x BCM currently.
I want to put a BCM Max in the car, and with that I want Bi-Xenon or Full LED lights.
I also want to install AFS in the future with these upgrades.
Can someone help me with parts and wiring. I'd love to be able to buy a pre made cable set.
Hopefully you guys will be able to help me out.
Andries
Re: Upgrading BCM, Exterior Lights, AFS
Andries Polo6R wrote: Mon Sep 25, 2023 11:59 am I do realize that this topic has been opened up many times before.
So did you read any of them?
Andries Polo6R
Yes I did, and to be honest there are so many that I get lost sometimes.
I watched multiple videos and read all threads about it on the forums I could find. I know I have to get a BCM max. I know I have to adapt the exterior lighting wiring to fit the new bcm, I need a new lightswitch as well.
My main question is, is someone able to make a wiring set for me?
To be honest, I think the wiring set is probably the smallest issue. You'll need to know exactly how to connect everything and actually do it.
If you think you can do that, making your own wiring is a piece of cake.
Andries Polo6R
I think I can do that. I have acces to proper wiring diagrams, I know how to resource parts. And Ive done oem retrofits with VCDS and Bcm wiring before.
I will try to make a conclusive list of parts that I need, I will post it here. Maybe when I'm done, you can check wether or not I need something else?
