Hi folks,
Hoping someone can find out or point me in the direction of part numbers/parts for the Sport Select shock absorbers?
These are the ones with adjustable dampeners using the “Sport” button on the dash. Lots of info for people retrofitting and such, but I just need to replace them for a warrant of fitness and would really rather not pay circa €700 for a single rear strut…
Help?
Help?! 6C Sport select suspension part numbers
Re: Help?! 6C Sport select suspension part numbers
Would you mind sharing your chassis no?
Yes. For the fronts you'll need 6C0 413 031 BT and for the rears you'll need 6C0 513 119 AS. if you're replacing them, it makes sense to also replace wearing parts like rubbers, coupling rods, etc.
- Drives: 2015 6c Sports select
Thanks so much for that - assuming the other parts are variant specific - or will generic ones do?
All other parts will be identical to the normal suspension cars. It's just the dampers and springs that differ. You need 18mm anti-roll bar rubbers (6Q0 411 314 R) for 20mm bar
