2015 6C airbag light, no horn, no MFSW
Andrewgas1
- Drives: 6C
My 2015 TDI r-line polo has thrown an air bag light, the horn doesn’t work and none of the buttons on the multi functioning steering wheel work. I’m guessing it’s the clockspring. Has anyone had any experience of a similar problem or knows the part number for a replacement clockspring? Also is it an easy fix or does anything have to be coded etc? Thank you
Bepis
- Drives: 2017 6C GTi Manual
Re: 2015 6C airbag light, no horn, no MFSW
Won't know for sure without plugging any diagnostics in but that screams clock spring to me.
broken tape. replace with same part number as on current spring. it's plug and play but you'll need to replace it correctly and clear the airbag light with diag scanner.
