Climatic issues
ChrisBrown
- Drives: 1.2 9n3
Climatic issues
Hi, my heater is either full hot or full cold. Chnaged the v68 flap control motor but still the same. Now thinking there must be some interior temp sensors which may be faulty. Any idea where they are, how i access and what part they are. Thanks
Re: Climatic issues
Wouldn't it be wise to first check measurement values for sensors and flap motors before replacing them? You can check with diag tool
- Maarten
Re: Climatic issues
Climatic of climatronic?
On climatic the check the valve under the throttlepedal.
And check vcds for faultcodes in adress 8
