I want to re-new my left engine mount. But the part number is confusing me.
My car is CAYB with KFK 5sp manual. By VW etka my part number is: OE 6R0 199 555 ( correct me if i'm mistaken)
I'm having a slight issue sourcing the part with that number ( 6R0 199 555 )
When I cross reference I see the 6R0 199 555 -> is same as 6Q0 199 555 just the last two letters are not the same.
I've found LEMFÖRDER 29978 01 ( From 9N 1.9TDI 74kw) that corresponds to OE 6Q0 199 555 AS, 6Q0 199 555 AR, 6Q0 199 555 AC, 6Q0 199 555 AE
This part new is priced at 46Eur, and I plan to fill in the gaps to give it extra strength.
Does anyone know will this part fit the KFK transmission?
Left engine mount
- Drives: 6C 1.0TSI 110BHP
Re: Left engine mount
You can use something like FEBI 19908 or 19904 I believe.amer6R wrote: ↑Fri Dec 29, 2023 7:32 pm Hi,
https://partsfinder.bilsteingroup.com/e ... ortdir=asc
I' will check if its available. Thanks!
- Le_Combattant
AS is the good one.
Im starting to think that the dimensions are all the same maybe the harness it a bit different.
I wish u all a happy holidays & new year
