1996 Door Mirror Help
Desmo
Drives: 1996 1.0
Post by Desmo »
Hi folks, newbie here.
Happy New Year to you all 🥳
I have a 1996 1.0 Polo, and i’ve got a problem in that I’ve damaged my l/h passenger mirror.
The main shell (green painted part) is ok but the inner bit with the mirror on is broken, and the black part that fixes to the door is broken.
Does anybody know how to remove the black part that fixes to the door?
I’m assuming this may involve removing the door card, so hints and tips on that would also be helpful.
Also, is it possible to separate the green painted shell from the part that fixes to the door?
Mirrors are electric.
Thanks 🙏
Maarten
Re: 1996 Door Mirror Help
Post by Maarten »
Behind the black cover inside the car
3 bolts/screws if I remember correctly.
Doorcard needs to be removed to release the connector
giannis20vt
Post by giannis20vt »
I found a video that might help you.
https://www.youtube.com/watch?v=VScUP9OS9NA
and this video for the mirror itself
https://www.youtube.com/watch?v=vW-fv00Z6og
Desmo
Drives: 1996 1.0
Post by Desmo »
Maarten wrote: Fri Jan 12, 2024 7:19 am Behind the black cover inside the car
Thanks Maarten.
Does the black cover just prise off?
Desmo
Drives: 1996 1.0
Post by Desmo »
giannis20vt wrote: Fri Jan 12, 2024 7:49 am I found a video that might help you.
Thank you 🙏
Maarten
Post by Maarten »
Desmo wrote: Fri Jan 12, 2024 1:44 pm
Thanks Maarten.
Yes you can pull it off
Just wiggle it a bit whilst pulling towards yourself
Maarten
Post by Maarten »
Video's are for the 6N2 (facelift model of the 6N)
But it is much like the 6N
