polo 6r door mirror wiring diagram and essentials
Yezdi_90
Drives: Polo 6r trendline
Post by Yezdi_90 »
Hi Guys,
I am looking to retrofit an electronic door wing mirror both driver side and passenger side, currently running on a joystick manual side mirror.
any help will be appreciated.
Re: polo 6r door mirror wiring diagram and essentials
did you consider heating the mirrors too? i'm not sure it's a factory option to have them electronically adjustable, but not heated.
i now you'll probably never need it in india, but might as well do it properly
Yezdi_90
Post by Yezdi_90 »
Oh thank you, yes I have seen people doing it.
I'm not looking for a heated mirror, it is quite redundant for me!
I just wanted to work on these mirrors and make it work.
Then I guess you'll need two RHD mirrors and the adjustment button. And of course some wiring
Yezdi_90
Post by Yezdi_90 »
Yes, Sir.
I sourced it from VW OE spare shops and took a wiring loom from a higher option. (both R and L)
-cleaned and prepped
- The adjuster got it from the same friend because he upgraded it to gti ( heated one).
Now I need a diagram so I can figure out what goes where as a reference.
Can someone help me out?
