Hi all,
I’m having trouble with the daily driver ATM, intermittently I get no dash lights when turning the key to the on position. If I cycle the key several times it comes back to life.
I believe it’s a failing ignition switch, without taking the steering column covers off I’m struggling to find a good part number.
Does anyone have access to a parts system ? The car is a 2007 3 door polo 1.4 16v BUD engine code.
Thanks in advance
Ignition switch part numbers
CarbonChaos
CarbonChaos
Re: Ignition switch part numbers
Perfect thank you very much
