Led fog lights
- J+silva
- Drives: polo conf.
Led fog lights
I would like to know if anyone has changed the fog lamps to LEDs or opted to install whiter lamps. What do you advise?
- Drives: 19plate AW GTI+ / (9n3 GTI gone)
Re: Led fog lights
You can fit LED’s but likely need coding changed to avoid errors.
- PO10ASH
- Drives: POLO GTI+
Re: Led fog lights
Swapped to LED and then coded them to LED so the warnings don't pop-up.
- J+silva
Re: Led fog lights
Thanks for the answers, I'll order the LEDs. Is there a procedure here on the forum to code for LEDs?
Re: Led fog lights
Someone with an idea how to use VCDS will be required.
- J+silva
Re: Led fog lights
Just a up date I changed the fog lights to leds cod it with obd and its 100% functional.
