i have errors where if i try to activate the heated wing mirrors, the front and rear wipers would activate. or another where the parking sensor alarm would go off when i'm nowhere near anything.
on research, i'd seen that a bad CAN unit can cause multiple issues, so i had removed the CAN and checked for any burning, etc. all was fine
i have brought up the diagnostic in VCDS and can see short to ground errors and CAN errors.
should i check the fuses first?
My diagnostic:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFY116808 Mileage: 170677km-106053miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 7876
Revision: R5H21---
Coding: 01110032232411080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS01104E906027BB 001005
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 65C104936461CFA350-8030
Center armrest control head 1:
8 Faults Found:
17158 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
12888 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
21742 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
P0219 00 [032] - -)
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
10591 - Cylinder 1
P0301 00 [096] - Misfire Detected
10592 - Cylinder 2
P0302 00 [096] - Misfire Detected
Readiness: 0000 0000
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08503513140712
Coding: 23DD2885492433C6091C10690059C41492CC90080005C7090C00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 6CD771B7878BFEEB0F-8038
1 Fault Found:
0608 - TPMS Display
C1146 F0 [137] - Not Available
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 30
Reset counter: 181
Mileage: 170289 km
Date: 2024.03.05
Time: 17:53:58
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0105
Serial number: 1407181B-0444
Coding: 200000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1D316C730CB1C763C8-8048
1 Fault Found:
262914 - Refrigerant Pressure
B10AB F0 [013] - Too Low
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 52272 km
Date: 2022.01.21
Time: 16:21:44
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009248002140
Coding: 03000840425300530BA44080B10703C800005B0257010000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMA0 004003
ROD: EV_MQBA0.rod
VCID: 2E53BBBF71174CFB61-807A
Driver door control module:
Subsystem 1 - Part No SW: 6R0 959 802 AT HW: 6R0 959 801 BB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU008071441893921
Coding: 1400A0
Front passenger door control module:
Subsystem 2 - Part No SW: 6R0 959 801 BB HW: 6R0 959 802 AT Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU008071441892887
Coding: 0400A0
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140942FY6
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000059642153
Rear Driver Side Door Control Module:
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU010071441911603
Coding: 1400A0
Rear Passenger Door Control Module:
Subsystem 6 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU014071441951014
Coding: 0400A0
5 Faults Found:
8458 - Bulb for Right DRL
B121E 15 [008] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 2
Reset counter: 209
Mileage: 156167 km
Date: 2023.12.13
Time: 19:06:29
9994 - Bulb for Right Parking Lamp
B12E9 15 [008] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 13
Reset counter: 215
Mileage: 161537 km
Date: 2024.01.17
Time: 17:49:17
136455 - Terminal 15
B1148 11 [008] - Short to Ground
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 170092 km
Date: 2024.03.04
Time: 17:47:40
137728 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 201
Date: 2000.00.00
Time: 00:00:00
228104 - Dual Washer Pump Input from SCS
B1830 29 [008] - Signal Implausible
Fault Priority: 6
Fault Frequency: 1
Reset counter: 194
Mileage: 137608 km
Date: 2023.09.05
Time: 08:04:03
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331420607120
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 3D718CF3AC71A763E8-8068
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag011 001 0330
Revision: -------- Serial number: 003LM003NAZV
Coding: 88C0C000000000005C000000008800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3169A0C3602953037C-8064
Subsystem 1 - Part No SW: ----------- HW: 410 822 406 14
Component: SideSensor_Df 151 0800
Serial number: 3575H00C91590262F20E
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 410 822 406 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00C915902617206
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 442 151 407 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00C916376B27307
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 442 151 407 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C916376B3C01C
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Component: KOMBI 211 0260
Coding: 272409002180260001086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009036
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 224B5F8F35CFF89BF5-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009248002140
Coding: 030100046F0A560071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_001_VW26.rod
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H03 0015
Serial number: 1821407413400719AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61192221172821539403
1 Fault Found:
65798 - Extended CAN in One-Wire Mode
U0054 00 [008] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 170092 km
Date: 2024.03.04
Time: 17:47:38
Terminal 30 power supply: 14.8 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE7N0334
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 3365AACB9A3561130E-8066
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 HW: 3Q0 035 874
Component: MU-S-ND-ER H04 0140
Serial number: VWZAZ2P4547990
Coding: 02620001BE00000011111201000808001F01008601200100C4
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 6FED66BBB69D05F32A-803A
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 6C0 919 603 A HW: 6C0 919 603 A
Component: ABTm_Std2_Nav H41 1017
Serial number: VWZ8Z9PH200A0V
Data carrier:
Subsystem 2 - Part No SW: 3G0 919 866 HW: -----------
Component: ECE 2014/15 --- 0235
11 Faults Found:
1597 - Data Set Implausible
B2012 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 68
Mileage: 54806 km
Date: 2022.03.17
Time: 19:09:56
Voltage terminal 30: 12.0 V
1598 - Data Set Implausible
B2012 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 61856 km
Date: 2022.05.04
Time: 19:36:46
Voltage terminal 30: 14.2 V
1555 - Check Software Version Management
B201A 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 237
Mileage: 114465 km
Date: 2023.04.22
Time: 11:14:14
Voltage terminal 30: 14.9 V
2562 - Navigation System
B126C F0 [009] - Navigation Database Faulty
Fault Priority: 6
Fault Frequency: 254
Reset counter: 168
Mileage: 52750 km
Date: 2022.03.03
Time: 20:17:39
Voltage terminal 30: 12.7 V
0518 - Front Right Treble Speaker
B1064 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 221
Mileage: 93369 km
Date: 2022.12.04
Time: 22:49:15
Voltage terminal 30: 12.4 V
0005 - Antenna Amplifier 1 for Radio
B126D 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 15
Reset counter: 186
Mileage: 159940 km
Date: 2024.01.06
Time: 13:28:38
Voltage terminal 30: 13.2 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: electrically OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: electrically OK
Status of antenna 1 for radio-Reception level antenna 1: 0 dB�V
0007 - Connection between Antenna Amp 1 for Radio and Antenna
B1272 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 18
Reset counter: 220
Mileage: 163981 km
Date: 2024.02.01
Time: 21:13:38
Voltage terminal 30: 14.7 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: electrically OK
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: electrically OK
Status of antenna 2 for radio-Reception level antenna 2: 0 dB�V
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 29
Reset counter: 220
Mileage: 120943 km
Date: 2023.05.29
Time: 21:26:48
Voltage terminal 30: 12.1 V
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: electrically OK
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: electrically OK
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
0014 - Connection between Antenna Amp 1 for Digital Radio and Antenna
B1274 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 12
Reset counter: 220
Mileage: 165789 km
Date: 2024.02.11
Time: 01:06:19
2565 - GPS Antenna
B1054 13 [008] - Open Circuit
Fault Priority: 4
Fault Frequency: 9
Reset counter: 220
Mileage: 130838 km
Date: 2023.07.29
Time: 10:15:00
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 219
Mileage: 120943 km
Date: 2023.05.29
Time: 20:29:17
error codes. unsure where to start
Return to “MK8 and MK9 (6R/6C) Polo (inc GTI) - Years 2009-2017”
Jump to
- Polo Forums
- ↳ ID. Polo (1st Generation)
- Classifieds
- ↳ Parts For Sale
- ↳ Wheels & Tyres
- ↳ Brakes & Suspension
- ↳ Cars Breaking
- ↳ Unsorted For Sale Posts
- ↳ Cars For Sale
- ↳ Wanted
- ↳ Group Buy
- Performance & Technical
- ↳ DIY Guides
- ↳ ICE
- ↳ Chassis
- ↳ Powertrain
- ↳ Detailing / Bodywork
- ↳ Electrical
- Non-Polo Vehicles
- ↳ Seat Ibiza
- ↳ Skoda Fabia
- Polo Community
- ↳ Announcements
- ↳ Club House
- ↳ YouTube Videos
- ↳ Photography and Photoshop
- ↳ Reviews and Features
- ↳ Meetings & Events
- ↳ Meetings & Events Gallery
- ↳ Members Rides
- ↳ Was that you?
- ↳ Virtual Post Cards
- ↳ Forum Technical Help!
