Condensation in Headlight
Pritesh222
- Drives: 2012 1.2 3 Cylinder
Hi Guys I had a small accident few months ago and damaged the brackets on my headlight, I managed to get new brackets and all is well however I have started getting condensation in the headlight. Anyone know the easiest way to remove this or unblock the vents just in case they are blocked. Photo attached. Thanks in advance
CarbonChaos
Re: Condensation in Headlight
The most likely cause for this in your situation is the head light is cracked from the impact, remove it and carefully inspect it.
