Polo 6R ABS long coding help
Shakeeb1
Drives: 6r 1.2 CGPA
Post by Shakeeb1 »
Mechanic had changed my ecu and instrument cluster thinking the ecu had gone dead but it turned out to be a break in the wiring!
Car now starts and drives with the original ecu and instrument cluster back
But now the abs module has lost it’s coding and is showing as zero’s
It’s a 6r 1.2 RHD CGPA with hill hold but no tyre pressure monitoring. Believe it’s 256mm front discs and rear drums
Can anyone help with the coding
Vin number: WVWZZZ6RZAU055630
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 31414 790 31414
   VCID: 020B3F0F990F189BD5-8056
3 Faults Found:
03306 - Coding Not Valid
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 96
                    Mileage: 182831 km
                    Time Indication: 0
                    Date: 2024.06.04
                    Time: 02:32:15
                    Hex Value: 0x0002
                    Hex Value: 0x0002
                    Hex Value: 0x32E7
                    Hex Value: 0x25AF
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 96
                    Mileage: 182831 km
                    Time Indication: 0
                    Date: 2024.06.04
                    Time: 02:37:02
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3251
                    Hex Value: 0x1BAF
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
01042 - Control Module; Not Coded
            000 - -
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 96
                    Mileage: 182831 km
                    Time Indication: 0
                    Date: 2024.06.04
                    Time: 02:37:02
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3211
                    Hex Value: 0x14AF
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Shakeeb1
Drives: 6r 1.2 CGPA
Re: Polo 6R ABS long coding help
Post by Shakeeb1 »
Anyone that can help??
There is one person, but other people didnt value or apriciate his time that it took to calculate.
Meanwhile you can try it yourself
https://skodapilot.com/espcalculator-bo ... i/?lang=en
Shakeeb1
Drives: 6r 1.2 CGPA
Post by Shakeeb1 »
Aah that’s a shame
I noticed @iichel knows his stuff but he must be the one then
I’ve tried that calculator and it errors. It also doesn’t have the option for the cgpa engine on a rhd, but i tried different combinations 40,41,42,43,44,45 and had no luck
My mechanic has the genuine vcds but he’s not much into technology or forums and hasn’t registered on the ross tech forum
Shakeeb1 wrote: Tue Jun 04, 2024 8:50 pm Aah that’s a shame
Well geniune or not, it will do what it needs.
If you cant calculate the correct coding, then the best option is odis online
Shakeeb1
Drives: 6r 1.2 CGPA
Post by Shakeeb1 »
Aah,
Do you know anyone around the Sheffield/South Yorkshire area?
