Hello all,
At the moment double-pressing the key fob all doors including tailgate are opened. I wonder is there a way to change byte coding in VCDS configuration to open all doors except tailgate when the key fob is double-pressed?
Polo 9N3 VCDS open all doors except tailgate
Re: Polo 9N3 VCDS open all doors except tailgate
no i don't think that's possible
- Maarten
No.
Only all or single door on first press (driversdoor)
Cheers! I ask this because for example Carista android app (doesn't support Polo 9N3) has option to enable/disable "Unlock trunk when doors are unlocked". I guess this could be done on Polo via VCDS just need to know which byte to change manually...
- Maarten
Not possible with VCDS on 9N3
- Maarten
9N3 you have to add numbers, not bits or bytes.
That started with the 6R polo
