Pr number for front pads and discs
JamesBGT28
Drives: BlueGT
Post by JamesBGT28 »
Hello all,
Please can somebody tell me what the pr number is for the front pads and discs on my 2015 BlueGT, 1.4TSI, 6C.
Thank you 🙂
Re: Pr number for front pads and discs
Not an answer as such, but why not wander along to your local VW dealership and ask, at the parts area, for a copy of "CAR DATA" for your exact car, that will list all options selected at the initial build.
This info will continue to useful as time goes on.
For example, I have just bought a pair of replacement rear dampers for a 2015 VW Polo 1.2TSI 110PS SEL from ECP, Sachs as fitted at factory, now, because I have a copy of car data for all our family VW Group cars, I worked out that I had been sold the wrong version of rear damper, after using ECP "contact us" link, and telling them the PR code for the rear shock absorbers, I was given a different ECP p/n which ended up with me being able to collect the correct, according to Sachs webcat, but this item does not tie in with what the ECP website offered for that car.
JamesBGT28
Drives: BlueGT
No worries. I’ve spoke to the parts department at my local VW dealer and I’m going to go down tomorrow to get myself a copy. I shall update this thread with the answer once I have the information.
JamesBGT28
Drives: BlueGT
As promised, the pr number for the discs is 1ZC, the data sheet only shows the discs pr number but I’m going to assume it’s the same for the pads as well(?)
Yes, so 288mm front discs with ATE FN3 callipers, easy to buy even genuine VW Group pads online cheaply, I bought a set for my wife's 2015 VW Polo 1.2TSI 110PS, that car does not have "wear sensor" so I had to cut the wear sensor lead off - which is exactly what the official parts listing states.
Edit:- so 5K0 698 151B for genuine parts or Pagid T1376 if buying from Halfords or ECP, the original factory fitted pads to my wife's 2015 Polo were VW rebranded Jurid pads.
I only needed to replace the pads as they showed uneven wear on the inner pads due to a build up of corrosion on the front discs, I replaced them with Pagid from Halfords as they get supplied by ECP but some times they are much cheaper than buying from ECP. Pagid (Geomet) 50315HC sourced from ECP stock no 104440798 £91.73
