Replace BCM
Danypolo5
Drives: Polo 9n3 1.4 tdi bnv
Replace BCM
Post by Danypolo5 »
hi,
I bought a new bcm for my polo 9n3 (6q0937049f) many people told me that it doesn't matter if it comes from a 3 or a 5 door. today it arrived and i immediately tested it on the bench, the new bcm comes from a 3 door (mine is a 5) and therefore i mount it but it doesn't detect the opening of the rear doors, in fact the courtesy lights don't turn on and in vcds it indicates N/A in rear doors. someone told me that it needs to be coded..but nobody knows how 😅 the basic coding is 09358 on both bcm 3 the can coding is 00014 always on both.
Someone are able to help me?
Maarten
Re: Replace BCM
Post by Maarten »
Does this BCM has 3 connector slots? Or just 1?
Top small square one is for alarm
Middle one for front doors
Lower one for rear doors
In the latest version on VCDS there will be a list of code optional.
Danypolo5
Re: Replace BCM
Post by Danypolo5 »
Maarten wrote: Mon Sep 09, 2024 9:35 pm Does this BCM has 3 connector slots? Or just 1?
I think you're talking about the comfort module, the bcm is thisImage
Maarten
Re: Replace BCM
Post by Maarten »
Yes you're correct my bad
Then it doesn't matter
6Q2 low line
6Q1 medium
6Q0 medium/high
Should work
Danypolo5
Re: Replace BCM
Post by Danypolo5 »
Maarten wrote: Tue Sep 10, 2024 11:43 am Yes you're correct my bad
6Q2 low line
6Q1 medium
6Q0 medium/high
Should work
As I wrote, the rear doors don't work (the courtesy lights don't turn on and the dashboard doesn't show the open door image)
Maarten
Re: Replace BCM
Post by Maarten »
Check Adress/Module 46 in VCDS
Look for the coding, could be coded for 3 door
Danypolo5
Re: Replace BCM
Post by Danypolo5 »
Maarten wrote: Thu Sep 12, 2024 10:12 am Check Adress/Module 46 in VCDS
46 is coding for 5 doors (central lock work)..repeat problem is bcm what elsa say 2 different integrate code..one for 3 doors and one for 5...all tell me that is possible to coding but no one is able to tell me how 😅
Think Only solution is gone back that bcm and search for 5 doors one 🤷🏻‍♂️
Maarten
Re: Replace BCM
Post by Maarten »
Maybe try central electrics (module 9?)
Maarten
Re: Replace BCM
Post by Maarten »
Are you certain that the pins for the rear doors are present in the BCM?
https://www.mypolo.nl/xenforo/threads/p ... 9n3.20621/
Check here for the pin layout of the BCM
I have the image in full scale if needed, just DM me
Danypolo5
Re: Replace BCM
Post by Danypolo5 »
Maarten wrote: Thu Sep 12, 2024 12:51 pm Are you certain that the pins for the rear doors are present in the BCM?
I've elsa..pin are the same and i try it on bench..for me is a eeprom program at all
In coding there is nothing for doors and in mother board are all full solder
Maarten
Re: Replace BCM
Post by Maarten »
Can't you copy coding from old BCM into this one?
Re: Replace BCM
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q0 937 049 F
Component: 0006 BN-SG. 2X36
Coding: 17422
Shop #: WSC 31414
VCID: 3D27C4886466458224D-50D0
From my ex-9N3 five-door, central locking with remote control, courtesy lights, footwell lights, etc... I think I activated everything that was possible.
Maybe there is a chance that you will find some new function... I no longer remember everything that I activated/coded in this BCM.🤷‍♂️
It is a LHD, meaning the steering wheel is on the left. I guess it will be fine for Italy. 😊
This was the last Autoscan I was able to do from this wonderful car before the new owner took it away.
Sunday,11,June,2023,10:02:36:32438
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWZZZ9NZ9Y032253   License Plate: W.I. OK!
Mileage: 125560km-78019mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ9Y032253   Mileage: 125560km-78019miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 03D 906 023
   Component: SIMOS91 1.2l 2VG    5414
   Revision: --H04---    Serial number: VWZ5Z0H5181160
   Coding: 0000071
   Shop #: WSC 00788 785 00200
   VCID: 5BE36A109F326BB23A9-5184
   VINID: 9E69EAAAA25EA89A400C20850C7F11B1EF
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 BC    HW: 6Q0 907 379 BC
   Component: ABS 8.0 front   H06 0003
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002082
   VCID: 7F5BFE802BEA9792761-50D0
Address 08: Auto HVAC        Labels: 6Q0-820-045-V1.clb
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0850
   VCID: 6A8D3FD44568023AB1F-50D0
   Coding: 17422
   Shop #: WSC 31414
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: 19 AIRBAG VW51 0P   0011
   Coding: 12601
   Shop #: WSC 00788
   VCID: 2C01F9CC8F1CDC0A833-50D0
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 823 T
   Component: KOMBIINSTRUMENT AGD V04
   Coding: 01131
   Shop #: WSC 00000
   VCID: 43D3B27002823372529-50D0
Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
   Part No: 6N0 909 901
   Component: 01K1 GATEWAY CAN    2X36
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70B92DBC63B4F8EAFFB-50D0
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER     AGD V04
   Coding: 01131
   Shop #: WSC 00000
   WVWZZZ9NZ9Y032253     VWZ5Z0H5181160
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10160
   Shop #: WSC 00788
   VCID: 6D8734C874861502D4D-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 3F Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 00788
   VCID: 3D27C4886466458224D-4B3C
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 6Q0 035 152 E    HW: 6Q0 035 152 E
   Component: Radio 9NK           0004
   Revision: 00001000    Serial number: VWZ4Z4H4030175
   Coding: 0020200
   VCID: 2C01F9CC8A1CDC0A833-50D0
End----(Elapsed Time: 02:28, VBatt start/end: 13.5V/13.5V. VIgn 0.0V)------
Maarten
Re: Replace BCM
Post by Maarten »
Scan from my old 9N3 5door 2008 United
Tuesday,13,February,2018,12:58:47:01249
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ9NZ9xxxxxx License Plate:
VIN: WVWZZZ9NZ9xxxxxx Mileage: 120330km-74769miles
Revision: --H04--- Serial number: VWZ7Z0H0638149
Coding: 0000071
Shop #: WSC 16106 161 161066
VCID: 5BB25B279921619A89-5072
Readiness: N/A
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP80.lbl
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 BG
Component: ESP 8.0 front H06 0003
Coding: 0002416
Shop #: WSC 00046 412 114688
VCID: 0E1462731A5384323E-5072
Address 08: Auto HVAC Labels: 6Q0-907-044.lbl
Part No: 6Q0 907 044 E
Component: CLIMAtronic PQ24 3805
Shop #: WSC 00000 000 00000
VCID: 3460D09B543F8EE268-5072
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Coding: 26558
Shop #: WSC 00046
VCID: 3E74F2B33A7354B28E-5072
Coding: 12601
Shop #: WSC 00046
VCID: 2C50C8FBDC0FD62230-5072
Component: KOMBIINSTRUMENT VDO V08
Coding: 07531
Shop #: WSC 00000
VCID: 438283475191395AE1-5072
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Component: 01K1 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 00046
VCID: 70E81C8B30A7F2C24C-5072
Component: IMMOBILIZER VDO V08
Coding: 07531
Shop #: WSC 00000
WVWZZZ9NZ9B025466 VWZ7Z0H0638149
Coding: 10140
Shop #: WSC 00046
VCID: 6DD605FF27951F2A67-5072
Address 45: Inter. Monitor Labels: 6Q0-951-171.lbl
Part No: 6Q0 951 171
Component: Innenraumueberw. 0019
VCID: 6FEA1FF72D99ED3A55-5072
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Component: 64 Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 3D76F5BF37754FAA97-4A3A
Address 76: Park Assist Labels: 7H0-919-283.lbl
Part No: 7H0 919 283 A
Component: Parkingsyst. 24 KUH 402
Coding: 00102
Shop #: WSC 00046
VCID: 3068DC8BF027B2C20C-5072
End-------------------------(Elapsed Time: 03:46)--------------------------
