Is it easy to replace a clutch in the 3 cylinder 1.2 petrol AZQ engine?
I’ve got the tools and skills to do most jobs and in the past have rebuilt engines on rear wheel drive cars, but haven’t done much with front wheel drive. Can I change a clutch on these cars on a driveway? Will I need an engine hoist? Will I need to get the car high off the ground? What problems should I be prepared for ?
2004 polo 1.2 clutch replacement
Bikergonebald
- Drives: 2004 1.2 Twist
scotspie501
- Drives: 2002
Re: 2004 polo 1.2 clutch replacement
it can be done if you have the right tools
clutch align tool but get it high so you can get under neath the box
good luck or get a local garage to give you a quote
