Problems scanning CAN Gateway with VDCS
L162LZ
Drives: 1.6 TDI 2010 6r
Post by L162LZ »
Hi All
My daughter purchased 2017 1.4 TDI Polo 6R this week (previously she had a 2010 1.6 TDI) When I try to scan it with VCDS I get an error on the CAN Gateway
Address 19: CAN Gateway (J533) Labels:. 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: --------
Coding: 030100044F0A590071000000000000010001010000000000000000000000
Shop #: WSC 31414 790 50316
GVL: 01443C0000000000400000000000480000000000000000000000000000000000
VCID: 2615FE48C862F79A3D7-8072
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Serial number: 1491714481130011AD3B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 D HW: 6C0 915 181 D
Component: J367-BDMHella H10 9070
Serial number: 5138254104
No ASAM data for: "" (VW26)
Because of the fault I cant do any adjustments on that module (greyed out) as I wanted to change the stop/start voltage to stop it functioning. I've been in contact with VCDS support and their only suggestion was to see if there was a GPS tracker or Black Box module piggybacking onto the ODB port. I've checked around today and cannot see anything.
Just wondered if anybody else had seen anything similar previously. All other modules scan OK
Cheers Dave :D
Re: Problems scanning CAN Gateway with VDCS
Do you have a legitimate hex v2 interface with a recent vcds version?
L162LZ
Post by L162LZ »
iichel wrote: Sat Nov 02, 2024 10:09 pm Do you have a legitimate hex v2 interface with a recent vcds version?
Yes its an original 10 vin cable and support added me to their beta channel to see if this would make a difference (but it didnt)
okay, that's a bit annoying. i saw you openend a topic on ross tech forum and i don't know how to how to solve it
