Help needed with 6r cbzb engine 77kw cooling system.
Posted: Sun Nov 10, 2024 3:42 pm
by mesitisg
So guys my Polo 6r with engine cbzb 77kw is misbehaving.
I have an obdii gauge and also the Carly obdii dongle both monitor the coolant temperature.
After 20 minutes driving with 20⁰c outside the coolant temperature rises to 102⁰c momentarily and then drops to 96⁰c. This cycle continues during the drive.
I have noticed that the rad fan comes on at 102⁰c for a few seconds only at the low speed and the temperature drops to 96⁰c.
The rad fan runs when the AC is on.
Before this begun the car would run steady at 96⁰c according to the obdii gauge.
I had the thermostat replaced yesterday and the problem persists. The water pump was replaced around 5000 miles ago.
When does the rad fan kick on?
Any imput much appreciated.
Re: Help needed with 6r cbzb engine 77kw cooling system.
Posted: Sun Nov 10, 2024 6:44 pm
by ciclo
It seems like normal behaviour of the cooling system within the appropriate parameters.
Posted: Mon Nov 11, 2024 7:32 am
by mesitisg
Thank you for the reply.
I worry that this temperature levels are too high and I believed that the radiator fan would come on at it's low speed at 96c.
Posted: Mon Nov 11, 2024 11:50 am
by ciclo
The coolant temperatures at which the fan turns on and off are appropriate, and it is also normal for the fan to run when the A/C is turned on.
The outside temperatures and the power/load required are determining factors 'for the times' in which the fan is working, which is not a cause for concern.
It is certain that the thermostat is working correctly, another thing is that the replaced pump is performing adequately or providing the correct flow.
Install a new pump if you think it is not working properly.
Use original spare parts on this occasion if you did not do so in the previous pump replacement.
Posted: Mon Nov 11, 2024 4:17 pm
by mesitisg
Thanks for your reply my friend. I will be keeping an eye on the coolant temperature with the OBD2 gauge and if it starts creeping upwards I will change the pump.
Posted: Mon Nov 11, 2024 7:49 pm
by ciclo
As a precatory measure, you can use your hands/take a look -with the engine cold- to check the vacuum lines or electrical connectors to ensure that the engine control unit or cooling system components are receiving the correct signals. Use a flashlight.
Posted: Mon Nov 11, 2024 7:53 pm
by Le_Combattant
No worries to have, a +100°C water temps is normal.
Posted: Tue Nov 12, 2024 11:00 am
by mesitisg
Thank you for your insights guys.
I tend to overthink things at times
Posted: Tue Nov 12, 2024 2:54 pm
by Le_Combattant
I had the same "issue" when trouble shooting my engine hesition when cold.
I was thinking about a bad temp sensor.
When I saw 106+ degrees I felt so bad. But after few research, it's perfectly normal.
Posted: Mon Nov 25, 2024 11:40 am
by Retali
Le_Combattant wrote: Tue Nov 12, 2024 2:54 pm
So what ended up being your problem and solution for the slaggish jerky hesitation ?
Posted: Sun Dec 01, 2024 2:20 pm
by Le_Combattant
This, carbon on the intake ports:
- PXL_20240228_125632473.jpg (2.1 MiB) Viewed 2701 times
Posted: Thu Dec 05, 2024 9:45 am
by Retali
Le_Combattant wrote: Sun Dec 01, 2024 2:20 pm
Thanx! How did you end up cleaning it ?
Soda blasting (or similar) in a workshop ? or did you do anything yourself ?
Posted: Thu Dec 05, 2024 10:40 am
by Le_Combattant
Retali wrote: Thu Dec 05, 2024 9:45 am
Ice blasting, company service (250 euros).
