Hello everyone,
Who can help me or tell me the manual method for long abs 9.0i polo 1.6 tdi 90cv 2012 coding because with esp calculator it doesn't give me the right coding.
here is the vin and the id
WVWZZZ6RZDY141480
Address 03: ABS Brakes
VAG number of calculator: 6R0 907 379 AS
Part and/or version: ESP9.0i front H01 0002
Software coding: 000000000000000000000000000000000000
Workshop code: WSC 01383
VCID: 8F705E9FF7DBF84256A-80DA
Advanced Identification/FAZIT
Serial number: --------------
Identification: BPA-085
Date: 07.11.12
Supplier number: 0060
Test bench number: 1084
Flashing status
Reprogramming attempts (application): 1/0
Flash date: 00.01.01
Miscellaneous
Material number: 6R0 907 379 AS
Design. computer workshop: J104
ASAM Dataset: EV_Brake1ESP90iBOSCH
ASAM dataset revision: 003020
VCDS info:
Labels: 6R0-907-37x-ESP90.clb
ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
THANKS.
Need help coding esp 9.0i 6R0 907 379 AS
CRISTO77176
- Drives: polo 1.6 tdi 90cv
CRISTO77176
Re: Need help coding esp 9.0i 6R0 907 379 AS
would like to know how to rebuild my long abs coding, because there is an error in espcalculator which rejects the code!
Could someone provide me with a diagram or the excel file not present in another discussion in order to be able to reconstruct this damn long code.
thank you very much.
CRISTO77176
Good morning,
I tried these combinations, but all rejected, anyone to help me please?
21DD2885212700C184181471845100421401
21DD2885212700C184181471845100421405
21DD2885212700C184181471845100421501
21DD2885212700C184181471845100421505
21DD2885212700C184181471845100420801
21DD2885212700C184181471845100420805
21DD2885212700C184181471845100420901
21DD2885212700C184181471845100420905
21DD2885212700C184181471845100421400
Thanks.
Thanks.
I am not aware or any excel files in the public domain sorry. I can probably make the coding but it's not for free.
CRISTO77176
Hi Iichel,
Thank you for your response,
However in this discussion viewtopic.php?t=74520 you put an Excel file to download which is no longer valid!
what's your price please?
Yes I took the excel file offline. The price for making a coding is €50 via PayPal.
CRISTO77176
Ok it works, I'm going to see if my friend is ok because it's his polo shirt that has the problem and he's a little broke, especially since it has 350,000km he doesn't want to spend too much money on it, that's why I'm trying to find an inexpensive solution.
Thank you Iichel if it's ok for him I will contact you privately if it's ok for you?
Yes you can write me a pm if needed
Spending money 'wisely' is an ART these days.
Finding cost-effective solutions requires certain skills. DISCOVER PRO on POLO 9N3.
https://www.drive2.ru/b/688378392701051609/
(https://www.youtube.com/watch?v=R_Ngg0ET3h0)
W tO W! ...
Tip:
keep your old vehicles for at least 10 more years, your wallet/pocket will thank you for not wasting half your life working for free if you buy a new vehicle that will NEVER be yours -electronically speaking, it will enslave you-.
Note:
I almost posted the requested ABS coding for free, I was notified that new posts had come in before submitting/clicking on my new post... it took me a couple more seconds because my wife called me for some 'really important thing' that I don't remember now.
W tO W! ...
Tip:
Note:
