Steering column noise (clonk)
Le_Combattant
Post by Le_Combattant »
Hello all,
Yesterday on the morning I just ended up with my night shift.
I let the car idle on the parking and for some reason, play with the steeringwheel.
Near neutral and by going left to right, a disgusting noise was audible.
https://youtube.com/shorts/I84AN_fgJgU
First time I heard this kind of noise.
After 60 km of highway, no more noise.
I'm not gonna jack up the car until...few days/week because of the rain unfortunately.
For info, the car just pass 171600 km and the steering ball joint are from factory.
According to some people, it's a pretty "common" failure on PQ26 platform (A1, Polo, Fabia) but they are all agree about the source:
-Steering column
or
-Steering rack
If you have any feedback, experience with this, I will be glad !
Have a nice weekend.
2226
Re: Steering column noise (clonk)
Post by 2226 »
That sounds horrible.
From the location, I would say universal joint on the steering column.
I'm sure steering rack would sound more muffled.
If there is wear on the rack, there should be a screw down there to take up some of the wear by moving pinion closer to rack gear. Or at least that's how it's been on every car I've had.
Le_Combattant
Fun fact, no noise on this morning.
Quite strange issue.
2226
Post by 2226 »
Super weird.
Le_Combattant
2226 wrote: Mon Dec 02, 2024 7:34 pmSuper weird.
Also, on official Workshop manual from VW there is a procedure to adjust steering rack pre load to correct this noise.
Quite interesting.
Tinman
Drives: Polo 6C 1.0 Litre R Line 110hp
Post by Tinman »
2226
Post by 2226 »
That's what I was referring to. Did that on my mk1 to take up the wear.
In a rack and pinion, the rack wears out around the pinion because that's where most movement is. The teeth compress/wear down. You adjust the bolt/screw to raise the rack closer to the pinion and take up the play. Do not over-do it as this will lead to binding of the rack and pinion gear set at the limits of the steering rack.
