Hi, I have a 2017 Polo (6R I think)
Earlier today my car wouldn't lock with the fob. I tried spare fob, also didn't work, but I was able to lock manually. Just now tried to unlock and neither fob nor manual unlock works, I'm totally locked out of the vehicle.
Any advice? I need to travel in the morning. Thanks
Can't unlock car
- Maarten
Re: Can't unlock car
Try press and hold trunk release button.
Doesn't the physical key turn in the barrel?
MrcPl
- Drives: 2017 POLO 1.2 TSI Match Edition 5dr
Thanks but no luck. Key turns in barrel but does nothing.
Also, temp is approx 1 degree c if that's relevant
MrcPl
I'm an idiot, it was the key fob battery.
Had no idea it would prevent manual entry.
it should allow manual entry with a dead battery. did you try to open it manually afterwards?
MrcPl
Manual entry now works with battery replaced, but didn't work with dead battery. I would have thought that manual entry shouldn't need the battery but apparently it does.
- Maarten
You should always be able to enter the car with the key.
MrcPl
That's what I would have thought, but not the case.
