T6 Multivan 11/2017
Shadow109
Drives: Vw t5.1 2013
T6 Multivan 11/2017
Post by Shadow109 »
I had bought a new T6 multivan 2017
 Thursday,26,December,2024,14:49:50:22797
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WV2ZZZ7HZJH043735   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 25 3C 55 5F 61 0B
VIN: WV2ZZZ7HZJH043735   Mileage: 140370km-87221miles
Address 01: Engine (J623-CXEB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 AE    HW: 04L 907 445 A
   Component: R4 2.0l BTD   H03 6206
   Revision: 23101001
   Coding: 00254014436401080000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_ECM20BTD03004L906056AE 004007
   ROD: EV_ECM20BTD03004L906056AE.rod
   VCID: F0B23DD7AA26035A2FB-80A4
   VINID: 9E60AAAAA1D8A9A6001031C314F1BA4E51
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5302
   Revision: 00H11V01    CVN: DE654C7D
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: BD2CD4E3ADF4BE32F4D-80E8
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62117000000811
   Coding: 307E4098656684810C7C0279A68721D378F700
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: C0D2AD17DA06D3DA9FB-8094
   Serial number: 16081713470786
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEAE13EFE072652AAD7-80AA
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E0 907 040 R    HW: 7E0 907 040 R
   Component: ClimatronicT5 H04 0613
   Revision: 00001K04
   Coding: 0004000503
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN75.rod
   VCID: B236F7DF64AA714A19F-80E6
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Component: Heckbedienung  H11 0303
   Serial number: BHB-0012507170015099
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 228170266
   Coding: 62F8793A0A21201301284F406CEB8FD4C084738960CD79603304003F0860
   Shop #: WSC 02739 022 1914976
   VCID: AB08EABB430020825A9-80FE
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 140817 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU014081772263749
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 R    HW: 7E0 959 802 R  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU011081772232469
   Coding: 1400A1
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170002129460057313
   Coding: B4FFFF
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231720601691
   Coding: 308109
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: F1B438D3A12C0A52205-80A4
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 0607170439A87C Dataset Number: 7E0114v____ 0009
   Coding: 00005000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: B63ECBCF88C26D6A357-80E2
2 Faults Found:
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 30
                    Mileage: 140363 km
                    Date: 2024.12.26.
                    Time: 00:17:57
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 13.0 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          [FAULT_MISALIGNMENT_VERTICAL]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 30
                    Mileage: 140363 km
                    Date: 2024.12.26.
                    Time: 00:17:57
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01V H08 0018
   Revision: --------    Serial number: 003V4003DRHC Dataset Number: 7E0003V____ 0912
   Coding: 000000000000000000000000000000003156
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: BB28DAFBB3E0B002CA9-80EE
   Serial number: 3495ZRB401G59OGCI0L5
   Serial number: 3505ZRB400E599BKJ0EJ
   Serial number: 3515ZRB400659GF2S9GP
   Serial number: 3525ZRB400659GF2N8MQ
   Part No SW: 7E0 920 880 S    HW: 7E0 920 880 S
   Component: KOMBI         H04 1109
   Coding: 140F010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: BA26DFFFBCDA890AD1F-80EE
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042205
   VCID: E88255B79276CB9A77B-80BC
   Component: IMMO          H04 1109
   Serial number:
   VCID: EA862FBF8CFAF98A61F-80BE
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
   Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
   Component: SWA Master    H08 0030
   Serial number: 0450411568
   Coding: 030311
   ASAM Dataset: EV_LaneChangAssis 001028
   ROD: EV_LaneChangAssis_VN75.rod
   VCID: B032FDD76AA6435A6FB-80E4
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0450495139
   Coding: 030311
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0FCA020001000000
   Shop #: WSC 02757 790 50316
   ROD: EV_HeadlRegulVWLWRCC.rod
   Part No SW: 5K7 035 200 L    HW: 5K7 035 200 L
   Component: MU-S--ER      H41 0449
   Serial number: VWZAZ2T5332837 Dataset Number: V03935266VJ 0001
   Coding: 06570000BE00000011110001000938001F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: AD0CE4A37D942EB244D-80F8
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B1A73
   Shop #: WSC 07422 003 1048576
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75885700001708100499
End----------(Elapsed Time: 01:45, VBatt start/end: 12.5V/12.5V)-----------
It will need A lot of work, but this time I will make the retrofits in a different way
Re: T6 Multivan 11/2017
I like it a lot. 😍
With a little magic and love from you it will be in perfect condition (reviewed scan).👍
Enjoy it!!!
patil
Post by patil »
That steering wheel cover reminded me of Michelin tyres mascot " bib" :P
Nice van👌
patil wrote: Thu Jan 23, 2025 9:00 pm That steering wheel cover reminded me of Michelin tyres mascot " bib" :P
Only ONE funny little man is allowed on this forum, the ballots were already distributed a long time ago... 'and the winner was' me. :mrgreen:
The rest of you have to be serious and kind people. 😄 🤗
That MFSW bib looks like a coiled snake, maybe it's to welcome Chinese New Year (January 29).🐍
Shadow109
Post by Shadow109 »
Nice van👌
It seems like your right, But eventually I will get rid of the steering wheel :mrgreen:
Shadow109
Post by Shadow109 »
ciclo wrote: Fri Jan 24, 2025 12:40 am
Indeed I Agree :lol:
Shadow109
Post by Shadow109 »
new scan after fixing all faults :-
Friday,08,August,2025,17:29:16:22797
VCDS Version: 25.3.1.0 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250408 DS365.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZJH043735   Mileage: 150170km-93311miles
   Revision: 23101001
   VCID: F0B23DD7AA26035AFFB-80A4
Readiness: N/A
   Coding: 0014
   ROD: EV_TCMDQ500021.rod
   VCID: BD2CD4E3ADF4BE3224D-80E8
   VCID: C0D2AD17DA06D3DA4FB-8094
   Coding: 01
   VCID: FEAE13EFE072652A7D7-80AA
   Revision: 00001K04
   Coding: 0004000503
   VCID: B236F7DF64AA714AC9F-80E6
   Slave 1:
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.lbl
   Coding: 62F8793A0A21201301284F406CEB8FD4C084738960CD79603305003F0860
   VCID: AB08EABB430020828A9-80FE
   Coding: 0228DD
   Coding: 0400A1
   Coding: 1400A1
   Coding: B4FFFF
   Coding: 308109
   VCID: F1B438D3A12C0A52F05-80A4
   VCID: B63ECBCF88C26D6AE57-80E2
   VCID: BB28DAFBB3E0B0021A9-80EE
   Crash sensor for side airbag: passenger side:
   Coding: 140F010300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: BA26DFFFBCDA890A01F-80EE
   Revision: B9082001
   Coding: 042205
   VCID: E88255B79276CB9AA7B-80BC
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: EA862FBF8CFAF98AB1F-80BE
   Coding: 030311
   VCID: B032FDD76AA6435ABFB-80E4
   Coding: 030311
   ROD: EV_HeadlRegulVWLWRCC_VW46.rod
   VCID: AD0CE4A37D942EB294D-80F8
   Coding: 030B1A73
End----------(Elapsed Time: 01:46, VBatt start/end: 12.4V/12.3V)-----------
---------------------------No fault code found.----------------------------
