1.2L CGPB Consuming Oil
callumhind
Drives: 2014 1.2L Match Edition
Post by callumhind »
I have a 1.2L 3-cylinder (engine code: CGPB) with 150 000 miles that appears to be consuming oil a bit more quickly than anticipated. I'm having to top it up every 3-4k miles at the moment, and I'm a bit stumped as to what could be causing it.
The only thing that is slightly off with the engine is that when the oil filler cap is removed, it seems to take a short moment to get back to a normal idle speed, and when the cap is put back on, the engine speed slows down (almost to the point of stalling), and then picks up speed again and stabilises.
The only suggestion I've had is the PCV valve needing replacement, but that's as far as I've managed to get unfortunately.
Not a massive issue as I'm doing oil changes more regularly due to the high mileage (although a large portion of these is motorway miles), but was wondering if anyone has experienced this issue before, and if so, how they sorted it (hopefully by not scrapping it lol).
2226
Re: 1.2L CGPB Consuming Oil
Post by 2226 »
No harm in replacing the PCV valve anyway at that mileage.
Could be rings or cylinder liner wearing out too. Do a compression and leakdown test.
Blancomcr
Drives: Polo 1.2 CGPB
Post by Blancomcr »
Hiya,
Compression test?
If you leave it to idle for 5/10 mins when warm does it smoke under revs?
Blancomcr
Post by Blancomcr »
Sorry, didn’t see your reply.
