6R & 6C centre air vents and buttons
Aquavalver
Drives: 2013 Polo Blue GT
Post by Aquavalver »
Just a quick question -does anyone know if the 6C centre air vent section and buttons also fit in a 6R? Obviously to fit the 6C buttons in a 6R, you need to change the air vent section as that has the button surround & holes, so just checking that there isn't anything preventing this?
Re: 6R & 6C centre air vents and buttons
you do need a different radio frame and i dont have a part number for that.
Aquavalver
iichel wrote: Tue Feb 25, 2025 6:52 pm Image
Thanks! No worries, I can probably find that out. I see all your switches light up-do they all work including the sport mode one? Is it much work to get the passenger air bag working as it should? I have found out that there are 2 different black shades that the buttons come in (6R and 6C), so you need to be careful which ones you get as it's most annoying when they don't match!
i had to replace the airbag module to enalbe the deactivation of the passenger airbag. yes the sport button does indeed work, i have retrofitted the dynamic chassis control
Aquavalver
iichel wrote: Tue Feb 25, 2025 8:24 pm i had to replace the airbag module to enalbe the deactivation of the passenger airbag. yes the sport button does indeed work, i have retrofitted the dynamic chassis control
Wow! That sounds like a lot of work!
Good thing I all wrote it down haha! viewtopic.php?t=65724
