Hello,
I currently have an aftermarket radio from aliexpress and am considering installing a cluster with MFA plus, is there a way to connect the radio with the cluster to have the bluetooth information showing on it?
this is the radio : https://fr.aliexpress.com/item/10050037 ... pt=glo2fra
MFA plus with aftermarket Radio
- Showza
- Drives: 6R 1.6 TDI Sportsline
Re: MFA plus with aftermarket Radio
i guess the best way to find out is to ask the seller
- Showza
Alright thank you, do you know about the rcd 330 radios you can find with carplay/android auto unlocked? Maybe I want to change to a OEM radio so I can have better sound quality but am wondering if the "chinese" units like on https://www.rcd330.co.uk/products/rcd330 will connect to cluster? And if the sound is actually like in original radios or is it all chinese inside
