Hello
I am new to this forum.
My son has a 2011 Polo and it has had an airbag light on for sometime. Garage replaced passenger airbag in dash/above glove box with a 2nd hand one bought online but the light has come back on after a week.
I have another one bought online to see if it does it again but before I fit it, a friend also lent me their old VCDS and the fault shows as below.
Can anyone offer any help.
Does this fault mean passenger side airbag in dash or passengers side airbag in seat?
Also is the igniter part of the airbag or something different.
Google shows lots of faults come from the wiring under the passenger seat as it get moved all the time when people get in the back.
thanks for your help
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag01X H09 0020
Revision: -------- Serial number: 003GX00LMMUI
Coding: 003158
Shop #: WSC 00788 648 00255
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A9B94C1EDC77A4E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40650HJHG9OH.
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB40670HJHGD104
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB40510H4DU4ODM
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405P0BEE8CO6V
1 Fault Found:
9439761 - Front Passenger's Side Airbag Igniter
B100A 11 [136] - Short to Ground
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Mileage: 157299 km
Date: 2005.14.06
Time: 17:03:45
Airbag light and fault 9439761 - Front Passenger's Side Airbag Igniter B100A 11 [136] - Short to Ground
pologeorge
- Drives: polo 2011 1.2 petrol
Re: Airbag light and fault 9439761 - Front Passenger's Side Airbag Igniter B100A 11 [136] - Short to Ground
garage replaced the wrong airbag, this is the one in the seat
check the yellow plug underneath the seat, see if it's damaged or has any corrosion on the plug
pologeorge
Hi iichel
Thanks so much for your reply.
I was thinking this too because of the way the fault is written
Front Passenger's Side Airbag Igniter - does that mean passenger's side air bag (seat) or passenger side airbag (dash)
I will have a look under the seat and see what I can find.
thanks again
thanks again
this is the airbag in the seat
pologeorge
I had a look at the yellow connector but there didn't seem anything wrong with it.
Put it back together and coded out the fault. We are going to see if it comes back on if we don't move the seat.
When we have to move the seat and the light does re-appear then we know something is wrong under there and perhaps get a replacement seat or cut the connector off and hard wire the wires together as I have seen elsewhere on the web.
cheers
cheers
From some personal experience the connector often caused issues ( many vag models with age).
Maybe try removing neg battery lead, and clean the connector. ( I have found interdental teeth brushes to fit perfectly in various connectors and clean the without damaging)
You can find them in DM
Get the thinnest ones, + some contact cleaner. Let it dry then replug everything back
pologeorge
thanks I will have a go with these.
Light came be back on when somebody sat in the passenger seat
cheers
cheers
