Help required to swap IMMO data between Polo 6R clusters
Hi guys, I have got two diesel Polo 6r IND clusters with me. One is a lowline(Red backlight, 24C32) from a 2013 car and the other is a midline(3/4 white display, no eeprom NEC 3524 MCU) from a 2015 car. I was able to get unencrypted data out from both the clusters using an Autel IM608, but for some reason Autel doesn't allow editing plain text IMMO values. You can only save the IMMO data in its storage(which is fully encrypted in case of NEC35xx, unencrypted but with checksums in case of 24C32) and it doesn't allow reading NEC35xx saved IMMO data in 24C32 section and vice versa. What options do i have from here, if it's even possible? Any help would be appreciated.
