Help with retrofitting BCM-Max + Automatic lights
Dykau
Drives: Polo 6R 2010
Post by Dykau »
Hi, i'm currently installing a Discover Media (5C0 035 68 0G). I'd like to remove the dashboard for this (to lay all the cables as OEM as possible). Since the dashboard is already out, I wanted to retrofit a few things:
  • BCM Max (7E0 937 090 C -> later updated to 7E0 937 090 E)
  • Interior mirror from the T6 with FLA/HLA (7E0 857 511 F) and rain light/sensor (5K7 855 559 C)
    • (New windshield with new bracket already installed)
  • Light switch with auto light
  • cruise control
cruise control and Interior mirror from the T6 with FLA/HLA
It should be pretty straightforward. The circuit seems very simple and shouldn't be a problem.
(I would install the LIN cable directly for a later MFL retrofit).
Unfortunately, I couldn't find a circuit diagram for the conversion so that I could build the wiring harness. Unfortunately, I couldn't find one :(
I would be grateful if you could help me out here (If you have any further tips that I can incorporate directly (such as the LIN line), I would be very grateful). Please find attached a current AutoScan.
*EDIT*
I cannot add AutoScan as code because I received the following message:
"Forbidden. Contains contacts. Message seems to be spam. Anti-Spam by CleanTalk."
*EDIT2*
I removed "Shop", "VCID", "ASAM Dataset", and "ROD" to avoid the error message.
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZAY000000   Mileage: 000000km-000000miles
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BH    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV   8327
   Revision: --H09---    Serial number:
   Coding: 0000071
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 210228E3217000B8842914E484DA00401300
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 0204
   Revision: V0000000
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 322091088
   Coding: 24B02BBF08A10000003000007C2B0DD00040410F60840000200000000000
   Subsystem 1 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0902
   Serial number: KU0-KU017.11.0914803
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU012.11.0913371
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU009.11.0913531
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU010.11.0915362
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71390932105907
   Coding: 100001
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag008 H09 0018
   Revision: --------    Serial number: 003DW009EUV3 Dataset Number: v00301656R0 0001
   Coding: 003038
   Serial number: 3572SRB400009E65110.
   Crash sensor for side airbag: passenger side:
   Serial number: 3582SRB400009E58B22A
   Serial number: 3516GRB4021CCFTBBS5R
   Serial number: 3526GRB4021CCFTATKF4
   Part No SW: 6R0 920 860 D    HW: 6R0 920 860 D
   Component: KOMBI         H03 0205
   Coding: 140E00
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   Component: IMMO          H03 0205
   Serial number:
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2I6865878
   Coding: 0500040002
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Re: Help with retrofitting BCM-Max + Automatic lights
Post by MrCollayder »
All the wiring you can find on superetka.com/elsa
It's free.
If you need more details you can search this forum or drive2.ru forum. Lots of polo 6R/61 users have retrofitted 090 bcm and 'assistance pack' including fla, rdks, autolight, mfa+/maxidot etc. Even kessy =))
Dykau
Post by Dykau »
Are there any instructions available? I have no problem building the cable harnesses myself or installing them directly in the vehicle. I just need some help with the cable harnesses. To avoid mixing things up, my plan is to “only” retrofit the BCM-Max for now and then do the rest step by step later. Unfortunately, Ciclo no longer manufactures BCM cable harnesses.
There is a picture showing instructions in the Ciclo sales thread, but unfortunately I can't find a link.
(Probably only available if I buy the wiring harness or personal tech support)
Hi, I spent many years trying to make sure you all (around the world) could install a BCM Max on your 6Rs/PQ25. It's the reason why you are here.
In good logic, I can help a bit but I do not provide personal assistance to manufacture the new wiring looms for BCM MAX Adaptation, there's a wealth of information on this and other forums.
In order for me to manufacture new wiring looms for others, you have to seduce me, TRUST is everything.🤷‍♂️
It's essential to know that each 6R has its particularities when it comes to correctly manufacturing the new wiring for BCM MAX adaptation. It's also important to know that, 'in general terms', there are two possible "starts" for the manufacture of new wiring looms for BCM MAX adaptation: 2008/9/10 ---> 2014/5 ---> 2019/22.
With the new IC/BCM CAN lines, you can install the BCM MAX that you have according to the Ross-Tech instructions. Everything will work as before (NP). Several faults will hang in the diagnosis, but this does not imply a decrease in the vehicle's performance.
Then you can go step by step solving the detected faults.
Dykau
Post by Dykau »
And that makes perfect sense. I've now started going through the circuit diagrams myself and I've already noticed a few things.
License plate light
Is it really necessary to change this? In the circuit diagram for the Polo in RU, the license plate light is also connected to T73b/7. However, it is also connected to T73b/4 and T73a/45. Does that mean it still seems to work without a change?
KL58 | Kl58d
I'm not sure how best to solve this. Do you go from T73b/4 to T6/3 (KL58 - In) and disconnect the old cable that was installed there?
Reversing lights
In the RU Polo, T73b/48 is connected to T2b/1 and to the rear lights.
In the EU Polo, T73b/48, T12b/12, and T2b/1 are also already connected. Hence the question => conversion necessary?
And that's as far as I've gotten. I'm only pursuing this when I have some time to search through the circuit diagrams.
If you have a European 6R, forget about comparing it to the Russian, Indian or Chinese Polo. These used relays or the light switch differently than the European 6R for some of the lights.
Due to the equipment you've indicated you want to install, you should focus your studies on the diagrams for the 2015 Transporter T6 and, as an aid, for the 2016 Amarok.
Compare them to your Polo 6R and create your new wiring.
In case you have any of the many BCM Max Adaptation guides I made, the premises were:
- Adaptable to any 6R (many different models = different factory wiring).
- Efficiency
- Ease of installation. It's not comfortable in any case. I'm not responsible for the design/construction of the Polo 6R, however, some PhD in communications sciences with a lack of skills suggested that my wiring looms were very difficult to install... (thanks for the support at that times).
Is going to Mars easy?
If I had had the choice, I would have been born in 2525 and not in these medieval centuries.🤭
Nowhere in the 6R diagrams is the difference between BCM Max and 'junk' BCMs explained.
You should know that only the 6R Bluemotion (7L6) and those with xenon headlights (7L3 and 7L6) left the factory with the old Re4 or MAX BCMs.
On the other hand, there are things that aren't explained in the diagrams and that are learned through experimentation and scientific thinking...
I know every position of the contact terminals or pins on the connectors for this "Adaptation Game" (wiring, coding, etc) of all PQ25s around the world, but it's best to figure out for yourself which is the best solution for each of the tasks ahead.
If you get stuck at any point, I suggest you take a look at several of my installation guides, maybe they will enlighten you.
