ESP8.2i front H05 0001 ❔
Back in the caveman days, I did a small study of this ABS module/unit.
These past few days, I've re-examined everything I could about this module without finding anything new.
If you know anything more about this module, please share it. Thank you.
Wooden ABS unit for the Flintstones car...🤭 (TP 1.6 ... 🤦‍♂️)
Re: ESP8.2i front H05 0001 ❔
you should have access to my google sheets spreadsheet with all coding info for long coding
Thanks Michel💎🤗, in addition to your great Excel spreadsheet that you sent me a while ago, for LC I used the user labels contained in ABS.zip posted in the fantastic Iprot💎🤗 studies, but we still can't resolve the remaining unknowns.
Actually, my question is if anyone has any manufacturing information, a PDF for example 🤭, or have personally tested or discovered something new (just as I discovered the SA 40304 for these ABS units).
These ABS units work fine, but they're already obsolete, so perhaps some information could be declassified or something similar. :mrgreen:
My main interest are the SAs for Adaptations.
Anti-Slip Regulation.
"ASR setting" has been added. Adaptation Channel 21. Values: 0, 1, 2.
:!: Under observation!
The greater the interference (value 2), the less slippage when accelerating.
I imagine it will be very useful for those of us who have tuned our engines and the vehicle is used by drivers with different driving styles. 🤷‍♂️
The ASR can always be deactivated from the switch if necessary (snow, mud) ...or etc.🤭
Please share your experience here, thanks!!!
