VCDS, Camera and Parking Sensors
5ergioMX
Drives: Polo 6R 2013
Post by 5ergioMX »
Hello, how are you? I wanted to see if someone could guide me or help me with a problem I have with VCDS, the reverse camera, and reverse sensors.
My Polo doesn’t have a factory-installed reverse camera or reverse sensors. Over a year ago, I installed a reverse camera that comes out of the rear door logo. Everything worked fine, and it appears on the screen. I didn’t have to modify anything in VCDS when I installed the camera.
Right now, I’m trying to install the 8K module for the reverse sensors. I’ve already done the installation, but now I’m dealing with VCDS. From Module 19 – Gateway → Installation List, I installed 10 – Park/Steer Assist. But when I do this, the camera stops working; nothing shows on the screen (When I put the car in reverse, I can hear the camera activate/open)
I can hear a beep from the sensor horn, but still nothing appears on the screen.
If anyone has had this problem or has any idea for a solution, I would really appreciate it.
Re: VCDS, Camera and Parking Sensors
Hi, in addition to activating module 10 in the GW installation list, you must, through coding or adaptation (depending on the type of module 10 installed), tell module 10 if you have RVC installed.
Auto Scan? or info of the installed module...
5ergioMX
Post by 5ergioMX »
Hi Ciclo, thanks for your help. I managed to get the sensors working, they now appear on my car’s screen. The only thing left is to make the camera show up. The camera I have is one I bought on Aliexpress; it connects to the reverse light of the taillight and sends the video signal through the typical yellow RCA cable. The parking sensors are also from Aliexpress, but those do come with a module that I connected to the car’s cluster. I’m also sharing the autoscan I did with VCDS—if you need anything, could you let me know how to get it?
AutoScan
Monday,15,September,2025,14:30:16:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWAU46R3DY251950   License Plate:
Mileage: 82670km-51368mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 2D 44 56
VIN: WVWAU46R3DY251950   Mileage: 82670km-51368miles
22-AWD -- Status: Cannot be reached 1100
2D-Intercom -- Status: Cannot be reached 1100
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HE    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 4037
   Revision: --H10---    Serial number:                CVN: 4F805CB1
   Coding: 001900D6200400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070HE 004006
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6CD771B7878BFEF307-8038
   VINID: 9E69D19441A20D4A4214124500C1071406
2 Faults Found:
6056 - No Communications with HVAC Control Module (J301)
          U0164 00 [040] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 67
                    Mileage: 82515 km
                    Date: 2025.09.15
                    Time: 00:15:05
                    Engine RPM: 862.00 /min
                    Normed load value: 4.7 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 75  C
                    Intake air temperature: 37  C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 11.374 V
                    Time since engine start: 2.7 s
                    Engine torque: 22.68750 Nm
                    Accelerator pedal travel-Accelerator position: 0.00 %
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: 1.500
6443 - Power Supply Terminal 30
          P1602 00 [032] - Voltage too Low
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 82675 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Coolant temperature: -40  C
                    Intake air temperature: -40  C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    CTR_RST_MC: 0
                    CTR_RST_MU: 0
                    Ambient temperature: 20.25  C
                    Engine torque: 0.00000 Nm
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 AQ    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Serial number: --------------
   Coding: 20DD2885222800C1041D146E445100000000
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0D111C33DC5157FBB0-8058
2 Faults Found:
0983 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
0885 - Immobilizer Control Module
          U0167 00 [008] - No Communications
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397998E3B0599B5BCC-806C
5 Faults Found:
01336 - Company Data Bus for Comfort System
            014 - Defective - Intermittent
                    Fault Status: 00101110
                    Fault Priority: 6
                    Fault Frequency: 148
                    Reset counter: 126
                    Time Indication: 0
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 126
                    Mileage: 82515 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:13:43
00532 - Supply Voltage B+
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 109
                    Mileage: 82515 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:13:43
01317 - Control Module in Instrument Cluster (J285)
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 82675 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:01:48
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 0 km
                    Time Indication: 0
   Part No SW: 6R0 937 087 M    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H32 0407
   Revision: BF032001    Serial number: 0540 082131159
   Coding: 3DB02BBF08E32400923808003C2B0CD00040410F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 479DEE1BF6ADFDAB4A-8012
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU011031300010593
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU014031300013096
   Coding: 18BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2961514284801372AA2B
   Coding: 250000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU012031300017984
   Coding: 18BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU012031300012804
   Coding: 18BC32
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 35831415802218
   Coding: 100001
   Shop #: WSC 00081 790 00133
   VCID: 3B7582EBB265A94BDE-806E
   Component: VW10Airbag00E H10 0020
   Revision: --------    Serial number: 003GW00HTPB4 Dataset Number: v00304816R0 0001
   Coding: 003045
   VCID: 4999E823E8B90BDB5C-801C
2 Faults Found:
12670208 - Databus
          U1122 00 [008] - Implausible Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
12674816 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
   Part No SW: 6R0 920 860 K    HW: 6R0 920 860 K
   Component: KOMBI         H05 0605
   Coding: 140A00
   VCID: 3C7781F7B76BAE73D7-8068
1 Fault Found:
12653568 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 207
                    Mileage: 81683 km
                    Date: 2025.04.01
                    Time: 11:09:11
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H32 0407
   Revision: BF032001
   Coding: 002200
   VCID: 70EF65C7A3A31A133B-8024
3 Faults Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
01324 - Control Module for All Wheel Drive (J492)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 82675 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:00:53
02065 - Control Module for Speech Amplifier (J656)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 82675 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:00:05
Address 22: AWD
Cannot be reached
   Component: IMMO          H05 0605
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB77AF8D7FE0C375-803E
Address 2D: Intercom
Cannot be reached
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 10150
   Shop #: WSC 00788
   VCID: 306FA5C7F7235A137B-8064
1 Fault Found:
00566 - Steering Assistance Operation
            27-10 - Implausible Signal - Intermittent
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 1E000400040005
   Shop #: WSC 127395 840 08317
   VCID: 4683E31FF1A7E4A3B1-8012
5 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 58
                    Reset counter: 86
                    Mileage: 81804 km
                    Time Indication: 0
                    Date: 2019.08.28
                    Time: 13:39:41
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 40
                    Mileage: 82515 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 23:24:19
                    Fault Priority: 6
                    Fault Frequency: 22
                    Reset counter: 126
                    Mileage: 82515 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:03:56
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 126
                    Mileage: 82540 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 22:29:10
02873 - Control Module for Back-Up Camera (J772)
                    Fault Status: 00110100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 82675 km
                    Time Indication: 0
                    Date: 2020.02.06
                    Time: 00:03:17
End-------------------------(Elapsed Time: 03:28)--------------------------
Basics for VCDS or any other diagnostic tool:
- AutoScan or Clear all DTCs: IGN ON, ENG ON. (in most cases)
- Any other diagnostic procedure such as coding/adaptation/flashing, etc.: IGN ON, ENG OFF, and turn off all battery-draining electrical devices such as lights, radio, A/C, etc. The battery is not an infinite resource!
Correct the GW installation list in module 19.
- You must check or uncheck the modules that are or are not installed in your 6R.
- In your case: uncheck addresses 22 and 2D, and then check 56. Save.
Address 10:
- Verify Adaptations: Visual display for Park Assist - Rearview camera.
- New coding: 308001 (security access is required, enter -71679- before coding)
Address 56:
-Code correctly. The label contains the bit descriptions you should mark according to your vehicle's equipment.
eg:
Verify all Bytes! ... (graphics-6R)
New Autoscan:
Autoscan, GW installation list, Clear all DTCs, Done. Start new autoscan. Save.
You may need to RESET the radio or perform a new ignition cycle, or both. (RESET: press the on/off or MENU button on the radio for 10s)
I don't know the exact procedure for 'this radio' to make the changes take effect.
