ESP 8.2i Long Coding
BaileyFenn
Drives: Polo 6R 1.2tdi Bluemotion 2010
Post by BaileyFenn »
Hi All,
Recently have had an issue with my ABS Module where it has dropped the coding, I have attempted to use the calculator to generate the long coding however it doesnt have the correct selection for RHD with my engine code, would someone be able to assist with generating the long coding
Engine Code: CFWA
ABS Module: Bosch ESP 8.2i
Body Type: Polo Hatch
Brake type: 256mm front disk 200mm rear drum
Transmission: 5 Speed Manual
It has indirect TPMS Fitted (flat tyre warning light),HHC, Auto Start/Stop
VIN: WVWZZZ6RZBY056840
I also am unsure what security access code is.
Many Thanks
BaileyFenn
Re: ESP 8.2i Long Coding
I have now tried 210024C2217200B8842D24E864D100920000
It returns error code 22
230224E3417200B8C42D24EA84D100921300
