Voltage drop on cold start when turning headlights on, smooth engine shutdown
MDemir
Drives: 6C
Post by MDemir »
Hi everyone,
I’m having a strange issue with my 2014 Polo 6C 1.4 TDI (CUSB) and I’m trying to understand what’s actually going on. When the engine is completely cold, turning the headlight switch ON sometimes makes the engine shut down very smoothly like a controlled start/stop event, even though start/stop is disabled on my car. Most of the time the engine restarts by itself as soon as I press the clutch, but occasionally I get a “Crank engine manually” message and I need to start it with the key. Once the engine warms up, the fault completely disappears and I cannot reproduce it no matter what I do.
When I checked with OBDeleven, things became much clearer. Exactly at the moment I turn the headlights on, the alternator load instantly jumps to 99% and the system voltage drops to around 12.3V. The ECU even logged a “low voltage” fault once. My battery is brand-new AGM, the car cranks perfectly, and there are no issues when the engine is warm. I also cleaned the battery terminals and the main chassis ground; the problem temporarily went away after cleaning but returned shortly after. There is an aftermarket head unit installed, but since the issue only happens under load while the engine is running, I doubt the radio has anything to do with it. If it were a parasitic draw or wiring issue, I would see the symptoms with the engine off, not only in cold idle with the headlights switched on.
I’ve taken the car to a few different mechanics, but the explanations I got don’t match the symptoms at all. Some blamed the battery brand or said the battery was weak, but the battery is new and a weak battery wouldn’t make the engine shut down smoothly while running. A couple of them mentioned a parasitic drain, but that would show up after the car sits overnight, not when the headlights are turned on during cold idle. Another mechanic suggested the aftermarket radio, but a head unit draws only a few watts nowhere near enough to push the alternator to 99% load and collapse the system voltage. One even suggested injectors, but an injector fault would cause rough running or a harsh stall; my engine shuts down smoothly because the ECU intentionally cuts fuel. Some tested the alternator with a digital meter and said everything looks normal, but these tests were always done with a warm engine, and the alternator behaves completely differently when cold. None of them tested the car during the exact moment the fault occurs: cold idle + sudden electrical load.
What seems to be happening is that when the engine is cold, switching the headlights on causes a sudden electrical load that the alternator cannot handle. The voltage drops to 12.3V, alternator load hits 99%, and the ECU enters low-voltage protection mode. It cuts fuel to protect the system, which explains the perfectly smooth shutdown. If the voltage drop is severe enough, the ECU refuses to auto-restart and displays “Crank engine manually.” As soon as the alternator warms up and the brushes/regulator make proper contact, everything returns to normal. This doesn’t match diode or stator winding failure, because those faults cause continuous issues regardless of temperature. My issue is strictly cold-only and load-dependent, which fits a weak regulator or worn brushes much more closely.
If anyone has experienced something similar on a Polo 6C / EA288 TDI or knows what else I should check, I’d really appreciate the advice.
