Coming Home(CH)/Leaving Home(LH) activation POLO 6C GTI
Speedhunter
Drives: 6C GTI
Post by Speedhunter »
Vehicle requirement:
1. Auto Light Rotary Switch
- PN: 5G0941431AFWZU (red backlight for GTI)
2. Rain-Light-Humidity Sensor (RLHS)
- PN: 5Q0955547A or 5Q0955547B
Check here for codeing:
viewtopic.php?t=80001
If above is succesfully done follow next steps:
Go to 09-Central Electrics -> Adaptation -> Comfort illumination and set following:
Coming Home Verbaustatus
-Automatic
Menuesteuerung Coming Home Werkseinstellung
-Active
Menueeinstellung Cominghome
-10 seconds
Coming home Leuchten
-Low beam
Coming-home Einschaltereignis
-Driver door
Helligkeitsschwelle Infrarot-Messung
-72.0
Leaving-Home Verbausstatus
-Enabled
Lho aktiviert
-Active
Lho zeit
-10 seconds
Helligkeitsschwelle Forward-Messung
-100
Some of the above adaptations can be altered at your preference and I will not explain them one by one for sake of my time and guide lenght.
Next go to 09-Central Electrics -> Adaptation -> Assistance light functions and set following:
AFL Zeitverzoegerung
-2000 ms
Assistenzfahrlicht bei Regen
-Active
Assistance lighting sensitivity adjustable
-Present
Done!
In car settings on MIB there should be additional options available concerning lighs and wiping, check them out.
Regards,
Speedhunter
Re: Coming Home(CH)/Leaving Home(LH) activation POLO 6C GTI
Thank you so much for such detailed information. 👍
It's very nice when someone takes the time to share information based on his tests/studies. 8)
Speedhunter
Drives: 6C GTI
@ciclo Apprechiate!
I’m new to the VAG platform and haven’t had much time to work with it yet, but I learn quickly.
I don’t plan to keep the 6C for long, as I’m planning to move up within the VAG range.
Still, I’ll be doing a few retrofits on it purely for the learning curve and to gain experience before moving on to another platform.
Also cars that age should come with all of this in first place and adjustments should be idiotproof on infotaiment system or dashboard. I understand people have fetish or someone is earning big money on retrofiting stuff but again most of this stuff should be there in first place; at least if not on basic model than on GTI or whatever. So my goal is to leave it very simple and straight foward guides so people dont pay and lose time for it.
Learning is the most valuable goal. 8)
Currently, in this world, you will encounter significant additional difficulties, not related to knowledge, that will try to diminish your enthusiasm for your ultimate goal, you must persevere and make sacrifices in the face of setbacks -The better the opponent, the sweeter the victory-. Willpower is your greatest ally, and often your only one.
Investing in achieving knowledge is the best of investments, it will help you a lot if you are fortunate enough to be someone creative.
