Adding "trip button" on wipers control
pyvinouze
Drives: Polo 6R STYLE 1.2 MPI
Post by pyvinouze »
Hello,
I just bought a Polo 6R 2011 Style finition and I was surprised it didn't have the button to change what is on the center screen (consomption, speed, autonomy). I would like to add this function.
Finding the part is not complicated but is anyone already did it ? Do I need to change the wiring or it's plug & play between the previous (without trip button) wipers command and the new one (with trip button) ?
I know I will need to buy and use VAG COM to implement the feature into the car system. Do you have the process for this particular function ?
Thanks in advance for your help,
Pierre-Yves
Re: Adding "trip button" on wipers control
you will need to run few wires to your instrument cluster,
and you will have to code the function using vcds, or something similar
pyvinouze
Post by pyvinouze »
Do you have a wire diagram or any material to understand what is the wiring ?
