Mk2/Mk3 how low can you gooo?
mk2keel
Post by mk2keel »
I was thinking about 60mm drop on 14" wheels with 50profile tyres but just out of interest how low can you go on 14" wheels, i dont want to go down to 13" wheels because i want my speedo to be mildly accurate.
Next thing is what is the best ride height for the RS bumpers, will 60mm do or do i need to go lower?
Can i go to 80mm with 14" wheels if i get the arches rolled?
Karl_CLCoupe
Post by Karl_CLCoupe »
Hmmm. I know that someone has gone 80mm on coilovers with the standard 13" steels, and there were one or two at Polo Show lowered 70mm on some phat 13"s. I think envy is -60mm on 15"s. Not sure what you could get away with on 14inchers though. Don't know if thats any help?
Karl.
tarquin bevilastard
Post by tarquin bevilastard »
my mk2 was 85 mm with standardish 13's on
Aphex
Post by Aphex »
my mk3 now has 185/60 sr13's
metz
Moderator
Post by metz »
tarquin bevilastard wrote:my mk2 was 85 mm with standardish 13's on
Iremember your lass saying the saloon didnt like wide wheels on the back mate...what would i get away with width wise in a 13" flavour?
-40mm
GroovyCarrot
Sponsor
Re: Mk2/Mk3 how low can you gooo?
Post by GroovyCarrot »
mk2keel wrote:i dont want to go down to 13" wheels because i want my speedo to be mildly accurate.
Hmm. Surely the 14" wheels will put your speedo out, not the 13" ones? Given that mk2's all came with 13" as standard...
ZOMBIE
Post by ZOMBIE »
Groovy Carrot- i think he means?- if he puts low profiles on the thirteens''
Anyway Ive got r15 195\45 tires on my 15s,6.5 inch wide [speedo is still accurate]. Its lowered -40mm and I have spaced the rear wheels. To be honest with you, without arch work i woud say you coud go -40mm back and -55mm front using lowering caps on 14s with 50' tyres on them.
My car couldn't be any lower on the back thats for sure!
It depends what thickness of wheel you want to run. Personally if you want to go for the low decked look, either;
Go for ATS 13s slammed 60mm or 15s 40mm.
Thing is with 15s there isnt hardely anything between the arch and the wheel but the car is higher [greater difference between road and sill]- it still looks the mutts nuts though with the wheels tucked in the arches. But if you want old skool go for 13s.
With 13s [low profile tyres] you get the opposite, the car is very low [sill to floor] but the wheel to arch distance is greater. Personally i prefer 15s on my car. good luck with what ever you chose let us know how you get on, jus one more bit of advice; avoid rolling arches as cars as old as ares have fairly brital metal that when banged or formed can easily crack [hope you got a welder handy!]. :lol: :)
