Hi.
Im trying to help my son with his 15 plate tsi polo. The headlight assembly lets the water in and it seems we need a new headlight. I can only find a new one from VW quoted at £255 inc vat. I understand the part number is 6C2941006B
Anyone find an alternative cheaper replacement that will fit correctly? Im struggling.
Thanks in advance
Headlight replacement queries
Re: Headlight replacement queries
AI can find the cheapest and closest place to buy the headlight you need.
It is necessary to adjust the headlight height once replaced. It's very easy, you can do it yourself.
If your headlights are worn out and you only replace one, there will be differences in the light they emit, so it's always best to buy both, or at least ensure they both have new bulbs (HB/LB/POS).
