I am hoping for some help regarding adding a "charisma" (sport) button to my 2010 AWD 6J Ibiza.
I already have a T6 BCM max, I am currently in the process of retrofitting EMPS from an early S1. I have the column wired up and responding, and have confirmed it has charisma steering profile capability.
Is the only way to get charisma mode working through having DCC and a J250 module? Or through a LIN-bus style with a drive select button on a wheel?
Any help would be much appreciated.
Latest autoscan I could find below, minus the changes for EMPS.
Matt
Sunday,26,April,2026,09:18:46:32543
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ13ZCV001199 License Plate:
Chassis Type: 13-VW36 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 22 25 44 55 56 0B
VIN: WVWZZZ13ZCV001199 Mileage: 214390km-133215miles
22-AWD -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Not registered 0011
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 6R0 907 115 HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH20--- Serial number:
Coding: 0403000C18070160
Shop #: WSC 66565 257 00032
VCID: 6FBBD9951B9AFD82671-803A
VINID: 9E69EAAAA043A939800010492464C7B843
Readiness: 0110 0100
Part No SW: 6R0 907 379 BG HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 21DD7885432B02C484191E72C256404D0905
Shop #: WSC 00049 770 00190
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: N/A
VCID: 045186392E9CEEDAAA3-8050
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
Component: LENKW.SENSOR H06 0060
Serial number: 25111204652021
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F4D14070840AFC7-802A
Part No SW: 6J0 820 043 E HW: 6J0 820 043 E
Component: Climatronic H03 0808
Revision: S0000000
VCID: 2615FCB1F8E0FCCAD47-8072
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 300172843
Coding: 3C8829FFC8F325009B2806C13EEB06C9F0C0712E00002061200000330800
Shop #: WSC 02739 534 139556
VCID: 2B030D85E302C1A20B9-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 151112 05 54 0403
Coding: 02242D
Subsystem 2 - Part No SW: 6R0 959 802 N HW: 6R0 959 802 N Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 3130
Coding: 030000
Subsystem 3 - Part No SW: 6R0 959 801 Q HW: 6R0 959 801 Q Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 3130
Coding: 020000
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Serial number: 005300005068
Coding: 000003
Subsystem 7 - Part No: 1K8 951 171 A
Subsystem 8 - Part No SW: 6JA 919 719 C HW: 6JA 919 719 C
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B1376220316
Coding: 001000
2 Faults Found:
00886 - Turn Signal Switch (E2)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 3
Mileage: 214393 km
Time Indication: 0
Date: 2020.09.16.
Time: 09:14:16
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Mileage: 214393 km
Time Indication: 0
Date: 2020.09.16.
Time: 09:14:18
Address 10: Park/Steer Assist (J446) Labels:| 6J0-919-475.clb
Part No SW: 6J0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H09 0016
Revision: -------- Serial number: 32961230301610
Coding: 100006
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_SE250ParkiAssis2 S01711
ROD: EV_SE250ParkiAssis2.rod
VCID: 372B21F52FCA75427F1-8062
Part No SW: 6R0 959 655 H HW: 6R0 959 655 H
Component: VW10AirbagA03 H08 0018
Revision: -------- Serial number: 003EQ0000M7T Dataset Number: s00302906J0 0009
Coding: 003033
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 47CB51355F2A05C20F1-8012
Serial number: 3496GRB402JD1BPUPREW
Crash sensor for side airbag: passenger side:
Serial number: 3506GRB402JD1BPV4J9Y
Part No SW: 6JA 920 940 D HW: 6JA 920 940 D
Component: KOMBI H01 0711
Coding: 110C01
Shop #: WSC 73430 031 00104
VCID: 3D2733DD0DF65F12A5D-8068
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002000
VCID: 6889B28932742ABA26B-803C
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 214393 km
Time Indication: 0
Date: 2020.09.16.
Time: 09:14:16
Address 22: AWD Labels: None
VCID: 55F78B7D9D06A7528DD-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Component: IMMO H01 0711
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DC8812CF818AA30F-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11221
Shop #: WSC 00020
VCID: 30391AE9C364A27A3EB-8064
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0147
Revision: 00H04000 Serial number:
Coding: 2688324
VCID: 3B233DC51F2251229B9-806E
Subsystem 1 - Part No: 7L6 941 329 C Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000041
Subsystem 2 - Part No: 7L6 941 329 C Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000041
1 Fault Found:
01316 - ABS Control Module
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 214393 km
Time Indication: 0
Date: 2020.09.16.
Time: 09:07:37
Voltage: 13.77 V
Speed: 0.0 km/h
ABS 0
Address 56: Radio
Cannot be reached
End----(Elapsed Time: 03:07, VBatt start/end: 13.7V/12.0V. VIgn 12.0V)-----
------------------------------4 Faults Found-------------------------------
