I am new here, and if possible would really like some advice from you knowledgable lot. I am looking to buy a 1992 mkIII Polo, standard squareback, not a coupe. It is a 1 litre (not sure of exact cc), and has done around 80000 miles. I'm going to use it as a winter car so I can take my Mini off the road for the winter so it doesn't get eaten by the salt, grit and water on the roads.
What sort of things should I be looking out for when I buy a Polo? Are there any mechanical items in particular that go faulty? Any common rust spots or mud traps that can be found? Any niggles with this sort of car that I should watch out for? Obviously I will check all suspension, engine, gearbox, brakes, subframes and the shell as much as possible, but are there any tell tale symptom's of faults or underlying faults? (for example rattle at tickover which stops when the clutch is depressed on a Mini is usually engine-box' transfer gears, which when they fail usually knacker the box').
I know that what I've asked is kind of like asking how long is a piece of string but I'm completely new to Polo's so any advice you could give me would be very much appreciated.
Thanks in advance,
Tom
