9n Chrome grille?
Petrified
Sponsor
9n Chrome grille?
Post by Petrified »
I was thinking of getting a new front grille. I want to get the Charatere one but then I saw this...from In.Pro on http://www.larkspeed.com
What do you think. It's about a 1/3 rd of the price too. It looks a bit Merc.
Hmmmm. :roll:
James
polo2k
Post by polo2k »
its only a 1/3 of the price cos its styick on strips that go onto the stock grill
des_pd_ tdi
Post by des_pd_ tdi »
I quite like it. But, it probably looks kack in the flesh and if you do have it you'd need to get a black VW badge for the front, otherwise there would be too much chrome.
Nelson_Wilbury
Moderator
Post by Nelson_Wilbury »
I quite like it, though like Des says it probably doesn't look that much in the flesh :cry: Theres also the fact that that'd be the only piece of chrome trim on the car :?
Very Passat W8 though :P
Next mod is gonna be the 9n Aluminium boot struts, £35 and i'll be fitting them myself for once (note: impending disaster!! See the 'Oops' thread :oops: )
polo2k
Post by polo2k »
usually there a 30 sec job if your replacing existing ones
dxg
Moderator
Post by dxg »
I heard a rumour that the polo's supposed to be getting a minor facelift soon. The front grill will have chrome added in a "U" shape around the edge (like the Passat), but not across the horiztonal slats. I don't know if this is across the range, or just for the more expensive options. Might be worth waiting for this part to become available.
Also, on polo9n - there's someone who has made a grill the same idea as this just by applying silver foil (adhesive heat shielding stuff from a builder's/plumber's merchant) to have worked.
dxg
Moderator
Post by dxg »
Next mod is gonna be the 9n Aluminium boot struts, £35 and i'll be fitting them myself for once (note: impending disaster!! See the 'Oops' thread )
I don't know anything about these - what can you tell me??
polo2k
Post by polo2k »
you might be able to use that under bonnet mirror film instread of plumers stuff
polo2k
Post by polo2k »
as for fitting the b oot struts look at each end of the strut and theres a metal clip that you need to slide a screwdriver under and then pry i=t off and watch it fly about 50 feet then to fit the new ones pry the clip up and fit then press on the clip
Nelson_Wilbury
Moderator
polo2k wrote:usually there a 30 sec job if your replacing existing ones
Usually, but not if i'm doing it!! :D
mole
Admin
Post by mole »
:lol:
polo2k
Post by polo2k »
itll be ok its not like you hve to follow road signs :P
Nelson_Wilbury
Moderator
polo2k wrote:itll be ok its not like you hve to follow road signs :P
:lol:
Something always goes wrong when I try. This is after I fitted my TT pedals...
...and lets not begin on when I tried to shorten my Ariel!! :oops:
