It doesn't happen. I dont know if theres is a fusible or where should I check
REVERSE PROBLEM
REVERSE PROBLEM
I know that when you press the back gear or Reverse Gear the back whoet light suposed to turn. Also if you have the AC on it will turn recilculing air off.
