K&N Panel Filter
Si_GTi
Moderator
K&N Panel Filter
Post by Si_GTi »
Couple of questions:
I've been quoted £59.99 for a K&N panel filter from Motormania just down the road. I know I can get it cheaper at Demon Tweeks in Wrexham but the cost of the fuel and mileage on the car would bring the overall cost back up to about the same cost overall. So is this OK value?
Secondly, I know its no BMC, but will I notice much of a difference?
Cheers :)
morrismen
Yep
Post by morrismen »
They are expensive, but have a lifetime guarantee (whatever that means!). The air flow through them is much more efficient and therefore the air to petrol mix is better and torque appears better - you don't get the lag from when the car has to suck the air through the old standard filter.
You can get one on eBay for £32.00 + postage if you search for Polo filters K&N etc.
CalvinGTI
Sponsor
Post by CalvinGTI »
I was gonna say same thing, ive seen em for as low as £23 with 3 hrs left to go on the bidding !
Best bet for sure is ebay Si_Gti
Calâ„¢
Si_GTi
Moderator
Post by Si_GTi »
Cheers guys, I'll have a look at Ebay later on - its blocked at work :roll:
CalvinGTI
Sponsor
Post by CalvinGTI »
Ever thought about looking at the BMC Panel Filter? Just a thought, im sure there just as good or better than K&N's
Calâ„¢
Si_GTi
Moderator
Post by Si_GTi »
I thought the BMC only came as a cone filter induction kit jobbie? I can't quite stretch to the cost of a BMC, which is why I'm investigating the K&N panel filter, which is a straight swap for the factory-fitted airbox filter :) nice and stealth...
CalvinGTI
Sponsor
Post by CalvinGTI »
Nope the BMC comes as a panel filter too. (although some are coned your right)
http://www.bmcairfilters.com/VisModel.asp
Put in your car details and you will end up with a list of all the non CDA air filters they do.
Hope this helps, to be honest id have a BMC panel filter over K&N just because ive always (and most ppl alike) have thought K&N suck.
Cal â„¢
Si_GTi
Moderator
Post by Si_GTi »
Cheers Cal. No prices listed though :? I'll have a look at some of the distributors.
morrismen
Prices here
Post by morrismen »
http://www.gsfcarparts.com/ - follow the link and go into the online shop. The K&N filters are all about £32.00 standard from spares dealers.
