just got a GT engine, but...
pete69zx
Post by pete69zx »
Just collected a GT engine with around 43K miles under its belt yesterday :)
Anyways, i believe it needs a new AFM. Any one on here know about a suitable 'upgrade' or 'replacement'... ie.. what cars can a suitable AFM/air filter box be sourced from?
I've been trying to use the ETKA, but... to no avail :cry:
Also, what is the code for the close ratio gearbox from a GT? Can a suitable replacement be sourced easily from another VAG model? If so... what cars can it be found on?
I think thats it for now...
Cheers.
Pete :idea:
ste mk1lx
Re: just got a GT engine, but...
Post by ste mk1lx »
pete69zx wrote: Also, what is the code for the close ratio gearbox from a GT? Can a suitable replacement be sourced easily from another VAG model? If so... what cars can it be found on?
if i'm right the GT has the 3F engine code,the gearbox codes for this are AHD and CEH I don't know which is the close ratio one but guess it's the latter :roll:
pete69zx
aloha to a fellow north easterner...
Post by pete69zx »
Now then fella. Glad to see another from my neck of the woods appearing on this forum ;-)
Thanx for your info about the gearbox, but i 'need' a little more 'sure footed' advice reegarding the codes & possible other VAG cars i could source one from.
Cheers.
Pete :idea:
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
CEH and AHD have the same ratios but the CEH has a different casing which means they accept LSD's.
As for the AFM you can either get one off a GT or NZ engine. You van also get a golf 8v GTi Afm (also on some passats) which is bigger but it doesnt always work very well with the gt engine. Whats wrong with the afm? Maybe it just needs adjusting?
hardhitter
Moderator
Post by hardhitter »
I've got an aif flow meter available. You can use a golf digifant one, but it's better to use the original one for now. You can use any Mk 3 gearbox, but they vary in ratios etc. The closest to a GT box would probably be the 1.0 litre 5 speed.
metz
Moderator
Post by metz »
Is that the ayz?
Gareth_GT_Hatch
AHZ is the close ratio 1 litre box thats the same as the GT box but with a shorter final drive (even worse on the motorway!) Yours is the economy 1.0 5 speed if its an AYZ, which is more like the 8p box on the standard 1.3. I'll let tahrey fill you in on the ratios. (Im sure he will)
Gareth_GT_Hatch
Go-on then I'll post em:
stats at 3000rpm, Speeds 1-5 185/50/14 tyres, taken from Mark Hunter's Illustrious table (Although most of these gearboxes were added for tahreys benefit and thirst for gearbox related knowledge)
AHZ 1 litre close ratio
12.88
21.33
30.30
40.54
52.31
AHD 1.3 litre close ratio
13.53
22.40
31.83
42.58
54.94
AYZ 1 litre economy
12.88
22.74
35.61
49.96
60.16
8P 1.3 litre economy
13.53
23.88
37.40
52.47
63.18
amstrange1
Post by amstrange1 »
I think you need to type more in your posts Gareth. Not nearly verbose enough to unseat Tahrey as mammoth waffley post champion...
Gareth_GT_Hatch
Apologies. Too busy. :wink:
metz
Moderator
Post by metz »
my gearbox seems to be middle of the road then by those figures..short first gear (as i know from the 2 seconds it lasts) but rest seems fine to run off the gt engine to me. :-D
pete69zx
Post by pete69zx »
Thanx for helping extend my knowledge base ;)
Cheers.
Pete :roll:
pete69zx
Post by pete69zx »
Incidentally... what location on the 'box' is the 3 figure identity code situated? (for future refference)
Cheers.
Pete :idea:
Gareth_GT_Hatch
Its on the highest part of the gearbox where the gearbox mates to the engine, directly under the themostat housing.
Krupa
Post by Krupa »
I've just been out to have a look and can't find the code on the gearbox, but my Service Schedule has AHD written in it next to 3F so I'm assuming that my car has an AHD 'box.
Was holding out a vague hope that it'd take an LSD, ah well.
